Unable to install Overkiz (by somfy)
I am trying to install the Overkiz (by Somfy) integration but each time I got an error message. And help will be very much appreciated.
Core 2024.11.0
Supervisor 2024.11.2
Operating System 13.2
Interface utilisateur 20241106.0
under HACS I installed the lastest Overkiz (by Somfy) - Custom component version
2.15.1
Le flux de configuration n'a pas pu être chargé: 500 Internal Server Error Server got itself in trouble
The error log is as follow
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
S'est produit pour la première fois: 18:19:44 (1 occurrences)
Dernier enregistrement: 18:19:44
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 172, in post
    return await self._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 179, in _post_impl
    return await super()._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 84, in _post_impl
    result = await self._flow_mgr.async_init(
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1301, in async_init
    flow, result = await self._async_init(flow_id, handler, context, data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1326, in _async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1518, in async_create_flow
    handler = await _async_get_flow_handler(
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3246, in _async_get_flow_handler
    await _load_integration(hass, domain, hass_config)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3223, in _load_integration
    await async_process_deps_reqs(hass, hass_config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 575, in async_process_deps_reqs
    await requirements.async_get_integration_with_requirements(
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 54, in async_get_integration_with_requirements
    return await manager.async_get_integration_with_requirements(domain)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 170, in async_get_integration_with_requirements
    await future
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 159, in async_get_integration_with_requirements
    await self._async_process_integration(integration, done)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 182, in _async_process_integration
    await self.async_process_requirements(
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 264, in async_process_requirements
    self._raise_for_failed_requirements(name, missing)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 292, in _raise_for_failed_requirements
    raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for tahoma not found: ['pyhoma==0.7.2'].
Remove the HACS version and just go for Overkiz in core. The version you use is more than 3 years old…
