This is a fresh install of home assistant on a nano pi neo2.
I’m running the latest version of armbian bionic.
I am just using the default config.
2018-09-05 21:45:56 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package home-assistant-frontend==20180903.0: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-xjrdt779/home-assistant-frontend/
2018-09-05 21:45:56 ERROR (MainThread) [homeassistant.requirements] Not initializing frontend because could not install requirement home-assistant-frontend==20180903.0
2018-09-05 21:45:56 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not install all requirements.
2018-09-05 21:45:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
- [frontend](https://home-assistant.io/components/frontend/)
Please check your config., notification_id=invalid_config>
2018-09-05 21:45:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
Please check your config. @ 2018-09-05T15:45:56.656940-06:00>>
