Unable to install package py-mini-racer
I use HA on a Raspberry Pi 4 and various integrations have the following error in the log:
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [99 lines of output]
running bdist_wheel
running build``
running build_py
creating build
creating build/lib
creating build/lib/py_mini_racer
copying py_mini_racer/py_mini_racer.py → build/lib/py_mini_racer
copying py_mini_racer/init.py → build/lib/py_mini_racer
copying py_mini_racer/about.py → build/lib/py_mini_racer
running egg_info
writing py_mini_racer.egg-info/PKG-INFO
writing dependency_links to py_mini_racer.egg-info/dependency_links.txt
writing top-level names to py_mini_racer.egg-info/top_level.txt
reading manifest file ‘py_mini_racer.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no files found matching ‘py_mini_racer/libmini_racer.glibc.so’
warning: no files found matching ‘py_mini_racer/libmini_racer.dylib’
warning: no files found matching ‘py_mini_racer/mini_racer.dll’
warning: no previously-included files matching ‘pycache’ found under directory ‘'
warning: no previously-included files matching '
.py[co]’ found under directory ‘*’
adding license file ‘LICENSE’
adding license file ‘AUTHORS.rst’
writing manifest file ‘py_mini_racer.egg-info/SOURCES.txt’
copying py_mini_racer/libmini_racer.muslc.so → build/lib/py_mini_racer
/usr/local/lib/python3.11/site-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
How do I get rid of the error and how exactly can I install the missing package?
Can someone please help?
