After upgrade to 0.63.0 I get these errors…
2018-02-11 10:54:46 ERROR (Thread-16) [homeassistant.util.package] Unable to install package python_openzwave==0.4.3: Command “python setup.py egg_info” failed
with error code 1 in /tmp/pip-build-zeebuos1/python-openzwave/
2018-02-11 10:54:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: timestamp=1518342886.946165, exception=, source=util/package.py, message=Unable to install package python_openzwave==0.4.3: Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-zeebuos1/python-openzwave/, level=ERROR>
2018-02-11 10:54:46 ERROR (MainThread) [homeassistant.requirements] Not initializing zwave because could not install requirement python_openzwave==0.4.3
2018-02-11 10:54:46 ERROR (MainThread) [homeassistant.setup] Setup failed for zwave: Could not install all requirements.
2018-02-11 10:54:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: timestamp=1518342886.9474702, exception=, source=requirements.py, message=Not initializing zwave because could not install requirement python_openzwave==0.4.3, level=ERROR>
2018-02-11 10:54:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: timestamp=1518342886.9480093, exception=, source=setup.py, message=Setup failed for zwave: Could not install all requirements., level=ERROR>
2018-02-11 10:54:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=140719484149096-11, service=create, service_data=title=Invalid config, notification_id=invalid_config, message=The following components and platforms could not be set up:
Please check your config., domain=persistent_notification>
2018-02-11 10:54:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
