Fresh install of hassio 0.84.6/ hassOS 1.13 on RPi with the community Node-RED addon 1.2.2. Tried installing the node-red-contrib-rfxtrx through palette manager but install fails. Following in the addon log:
3 Jan 08:06:41 - [info] Installing module: node-red-contrib-rfxcom, version: 2.6.3
3 Jan 08:10:17 - [warn] Installation of module node-red-contrib-rfxcom failed:
3 Jan 08:10:17 - [warn] ------------------------------------------
> @serialport/[email protected] install /config/node-red/node_modules/@serialport/bindings
> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=8.14.0 runtime=node arch=arm platform=linux)
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! stack at FSReqWrap.oncomplete (fs.js:152:21)
gyp ERR! System Linux 4.14.81
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /config/node-red/node_modules/@serialport/bindings
gyp ERR! node -v v8.14.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/[email protected] install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/[email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2019-01-03T07_10_17_473Z-debug.log
Sorry, another case of RTFM. Apparently, additional nodes are installed through the add-on configuration, parameter npm_packages, not the palette manager. Added ânpm_packagesâ: [
ânode-red-contrib-rfxcomâ ] to the config, restarted Node-Red add-on and all is well!
Added node-red-contrib-rfxcom to npm packages, but canât install
Always getting the âno prebuilt binaries foundâ warning for serialport and then it tries to build itself but there is no âmakeâ in the addon.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 3.0.3
You are running the latest version of this add-on.
System: HassOS 2.11 (armv7 / raspberrypi3)
Home Assistant version: 0.92.1
Supervisor version: 162
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
[cont-init.d] node-red.sh: exited 0.
[cont-init.d] user.sh: executing...
[13:42:44] INFO: Starting installation of custom NPM/Node-RED packages...
> [email protected] install /opt/node_modules/rfxcom/node_modules/serialport
> prebuild-install || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=10.14.2 runtime=node arch=arm platform=linux)
gyp ERR! stack at FSReqWrap.oncomplete (fs.js:154:21)
gyp ERR! System Linux 4.14.98-v7
gyp ERR! cwd /opt/node_modules/rfxcom/node_modules/serialport
gyp ERR! node -v v10.14.2
gyp ERR! not ok
npm ERR! errno 1
npm ERR! [email protected] install: `prebuild-install || node-gyp rebuild`
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! /root/.npm/_logs/2019-04-30T11_43_45_840Z-debug.log
[13:43:45] FATAL: Failed installing npm package node-red-contrib-rfxcom
[cont-init.d] user.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Been trying out adding system packages to make it work.
Adding the âlinux-headersâ made it work! Great.
Bunch of errors still indeed, but it loads up and I get messages from my rfxcom!
Good to hear! I have another issue with Node-RED that bothers me: If the machine/Hassio boots without connectivity. Node-RED will crash as itâs not able to get the custom modules and libraries.
Do you have the same issue if you try to reboot Hassio without WAN?
