Unable to install ZHA
I’m struggling to get ZHA installed and would appreciate help with a solution related to the output in my logs. I’m able to install zigpy-zigate==0.7.3 manually without errors???
Logger: homeassistant.util.package==>
  • Unable to install package zigpy-zigate==0.7.3: ERROR: Command errored out with exit status 1: command: /srv/homeassistant/bin/python3.9 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-zatjkqg4/rpi-gpio_cd5c52ddc9a241599ff535da92dfd515/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-zatjkqg4/rpi-gpio_cd5c52ddc9a241599ff535da92dfd515/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-hxskrr_r cwd: /tmp/pip-install-zatjkqg4/rpi-gpio_cd5c52ddc9a241599ff535da92dfd515/ Complete output (87 lines): running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-3.9 creating build/lib.linux-armv7l-3.9/RPi copying RPi/init.py → build/lib.linux-armv7l-3.9/RPi creating build/lib.linux-armv7l-3.9/RPi/GPIO copying RPi/GPIO/init.py → build/lib.linux-armv7l-3.9/RPi/GPIO running build_ext building ‘RPi._GPIO’ extension creating build/temp.linux-armv7l-3.9 creating build/temp.linux-armv7l-3.9/source gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/srv/homeassistant/include -I/usr/local/include/python3.9 -c source/c_gpio.c -o build/temp.linux-armv7l-3.9/source/c_gpio.o gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/srv/homeassistant/include -I/usr/local/include/python3.9 -c source/common.c -o build/temp.linux-armv7l-3.9/source/common.o gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/srv/homeassistant/include -I/usr/local/include/python3.9 -c source/constants.c -o build/temp.linux-armv7l-3.9/source/constants.o gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/srv/homeassistant/include -I/usr/local/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-armv7l-3.9/source/cpuinfo.o gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/srv/homeassistant/include -I/usr/local/include/python3.9 -c source/event_gpio.c -o build/temp.linux-armv7l-3.9/source/event_gpio.o gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/srv/homeassistant/include -I/usr/local/include/python3.9 -c source/py_gpio.c -o build/temp.linux-armv7l-3.9/source/py_gpio.o source/py_gpio.c: In function ‘PyInit__GPIO’: source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations] 1046 | if (!PyEval_ThreadsInitialized()) | ^~ In file included from /usr/local/include/python3.9/Python.h:145, from source/py_gpio.c:23: /usr/local/include/python3.9/ceval.h:129:36: note: declared here 129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void); | ^~~~~~~~~~~~~~~~~~~~~~~~~ .
Came here to say that I got the same problem with a slightly different failure running a brand new Raspi OS and a fresh Home Assistant.
Steps to reproduce:
  1. Downloaded the latest Raspberry Pi OS to a Raspberry Pi 4
  2. Installed Pi-Hole
  3. Installed Home Assistant Core
  4. Set up an account
  5. Tried to install ZHA integration.
Result:
Failed to install ZHA integration.
Source: util/package.py:99
First occurred: 2:52:55 PM (1 occurrences)
Last logged: 2:52:55 PM
Unable to install package zigpy-zigate==0.7.3: ERROR: Command errored out with exit status 1: command: /srv/homeassistant/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uv__a4ki/rpi-gpio/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uv__a4ki/rpi-gpio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-2fm1h3lw cwd: /tmp/pip-install-uv__a4ki/rpi-gpio/ Complete output (87 lines): running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-3.9 creating build/lib.linux-armv7l-3.9/RPi copying RPi/__init__.py -> build/lib.linux-armv7l-3.9/RPi creating build/lib.linux-armv7l-3.9/RPi/GPIO copying RPi/GPIO/__init__.py -> build/lib.linux-armv7l-3.9/RPi/GPIO running build_ext building 'RPi._GPIO' extension creating build/temp.linux-armv7l-3.9 creating build/temp.linux-armv7l-3.9/source arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/c_gpio.c -o build/temp.linux-armv7l-3.9/source/c_gpio.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/common.c -o build/temp.linux-armv7l-3.9/source/common.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/constants.c -o build/temp.linux-armv7l-3.9/source/constants.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-armv7l-3.9/source/cpuinfo.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/event_gpio.c -o build/temp.linux-armv7l-3.9/source/event_gpio.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/py_gpio.c -o build/temp.linux-armv7l-3.9/source/py_gpio.o source/py_gpio.c: In function ‘PyInit__GPIO’: source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations] 1046 | if (!PyEval_ThreadsInitialized()) | ^~ In file included from /usr/include/python3.9/Python.h:145, from source/py_gpio.c:23: /usr/include/python3.9/ceval.h:129:36: note: declared here 129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void); | ^~~~~~~~~~~~~~~~~~~~~~~~~ source/py_gpio.c:1047:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations] 1047 | PyEval_InitThreads(); | ^~~~~~~~~~~~~~~~~~ In file included from /usr/include/python3.9/Python.h:145, from source/py_gpio.c:23: /usr/include/python3.9/ceval.h:130:37: note: declared here 130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void); | ^~~~~~~~~~~~~~~~~~ arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/py_pwm.c -o build/temp.linux-armv7l-3.9/source/py_pwm.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/soft_pwm.c -o build/temp.linux-armv7l-3.9/source/soft_pwm.o arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,-z,relro -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.9/source/c_gpio.o build/temp.linux-armv7l-3.9/source/common.o build/temp.linux-armv7l-3.9/source/constants.o build/temp.linux-armv7l-3.9/source/cpuinfo.o build/temp.linux-armv7l-3.9/source/event_gpio.o build/temp.linux-armv7l-3.9/source/py_gpio.o build/temp.linux-armv7l-3.9/source/py_pwm.o build/temp.linux-armv7l-3.9/source/soft_pwm.o -o build/lib.linux-armv7l-3.9/RPi/_GPIO.cpython-39-arm-linux-gnueabihf.so /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:42: multiple definition of `both_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:42: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:41: multiple definition of `falling_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:40: multiple definition of `rising_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:39: multiple definition of `pud_down'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:38: multiple definition of `pud_up'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:37: multiple definition of `pud_off'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:36: multiple definition of `bcm'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:35: multiple definition of `board'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:34: multiple definition of `unknown'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:33: multiple definition of `spi'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:32: multiple definition of `i2c'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:32: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:31: multiple definition of `serial'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:31: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:30: multiple definition of `pwm'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:30: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:29: multiple definition of `output'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:29: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:28: multiple definition of `input'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:28: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:27: multiple definition of `low'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:27: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:26: multiple definition of `high'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:26: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/py_pwm.h:23: multiple definition of `PWMType'; build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/py_pwm.h:23: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: first defined here
I get that installing HAC is an “Advanced” workflow - but this is a really fresh system. This is the 2nd time as well that I’ve bumped into this - hence the fresh install.
Truncated the log as it was too long…
If anyone has any clue on how to resolve this, I would very much appreciate it.
More log
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/soft_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-armv7l-3.9/source/event_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/event_gpio.c:60: first defined here collect2: error: ld returned 1 exit status error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1 ---------------------------------------- ERROR: Failed building wheel for RPi.GPIO ERROR: Command errored out with exit status 1: command: /srv/homeassistant/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uv__a4ki/rpi-gpio/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uv__a4ki/rpi-gpio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-e8c_tyzc/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.9/RPi.GPIO cwd: /tmp/pip-install-uv__a4ki/rpi-gpio/ Complete output (87 lines): running install running build running build_py creating build creating build/lib.linux-armv7l-3.9 creating build/lib.linux-armv7l-3.9/RPi copying RPi/__init__.py -> build/lib.linux-armv7l-3.9/RPi creating build/lib.linux-armv7l-3.9/RPi/GPIO copying RPi/GPIO/__init__.py -> build/lib.linux-armv7l-3.9/RPi/GPIO running build_ext building 'RPi._GPIO' extension creating build/temp.linux-armv7l-3.9 creating build/temp.linux-armv7l-3.9/source arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/c_gpio.c -o build/temp.linux-armv7l-3.9/source/c_gpio.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/common.c -o build/temp.linux-armv7l-3.9/source/common.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/constants.c -o build/temp.linux-armv7l-3.9/source/constants.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-armv7l-3.9/source/cpuinfo.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/event_gpio.c -o build/temp.linux-armv7l-3.9/source/event_gpio.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/py_gpio.c -o build/temp.linux-armv7l-3.9/source/py_gpio.o source/py_gpio.c: In function ‘PyInit__GPIO’: source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations] 1046 | if (!PyEval_ThreadsInitialized()) | ^~ In file included from /usr/include/python3.9/Python.h:145, from source/py_gpio.c:23: /usr/include/python3.9/ceval.h:129:36: note: declared here 129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void); | ^~~~~~~~~~~~~~~~~~~~~~~~~ source/py_gpio.c:1047:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations] 1047 | PyEval_InitThreads(); | ^~~~~~~~~~~~~~~~~~ In file included from /usr/include/python3.9/Python.h:145, from source/py_gpio.c:23: /usr/include/python3.9/ceval.h:130:37: note: declared here 130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void); | ^~~~~~~~~~~~~~~~~~ arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/py_pwm.c -o build/temp.linux-armv7l-3.9/source/py_pwm.o arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.9 -c source/soft_pwm.c -o build/temp.linux-armv7l-3.9/source/soft_pwm.o arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,-z,relro -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.9/source/c_gpio.o build/temp.linux-armv7l-3.9/source/common.o build/temp.linux-armv7l-3.9/source/constants.o build/temp.linux-armv7l-3.9/source/cpuinfo.o build/temp.linux-armv7l-3.9/source/event_gpio.o build/temp.linux-armv7l-3.9/source/py_gpio.o build/temp.linux-armv7l-3.9/source/py_pwm.o build/temp.linux-armv7l-3.9/source/soft_pwm.o -o build/lib.linux-armv7l-3.9/RPi/_GPIO.cpython-39-arm-linux-gnueabihf.so /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:42: multiple definition of `both_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:42: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:41: multiple definition of `falling_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:40: multiple definition of `rising_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:39: multiple definition of `pud_down'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:38: multiple definition of `pud_up'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:37: multiple definition of `pud_off'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:36: multiple definition of `bcm'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:35: multiple definition of `board'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:34: multiple definition of `unknown'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:33: multiple definition of `spi'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:32: multiple definition of `i2c'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:32: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:31: multiple definition of `serial'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:31: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:30: multiple definition of `pwm'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:30: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:29: multiple definition of `output'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:29: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:28: multiple definition of `input'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:28: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:27: multiple definition of `low'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:27: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:26: multiple definition of `high'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/constants.h:26: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:38: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/py_pwm.h:23: multiple definition of `PWMType'; build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/py_pwm.h:23: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:41: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:40: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:39: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:37: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:36: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:35: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:34: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/common.h:33: first defined here /usr/bin/ld: build/temp.linux-armv7l-3.9/source/soft_pwm.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-armv7l-3.9/source/event_gpio.o:/tmp/pip-install-uv__a4ki/rpi-gpio/source/event_gpio.c:60: first defined here collect2: error: ld returned 1 exit status error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1 ---------------------------------------- ERROR: Command errored out with exit status 1: /srv/homeassistant/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uv__a4ki/rpi-gpio/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uv__a4ki/rpi-gpio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-e8c_tyzc/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.9/RPi.GPIO Check the logs for full command output. WARNING: You are using pip version 20.2.4; however, version 21.3.1 is available. You should consider upgrading via the '/srv/homeassistant/bin/python3.9 -m pip install --upgrade pip' command.
Same problem here. I tried to install zigpy-zigate==0.7.3 from pip but it fails to install RPi.GPIO any sign of that in your case?
export CFLAGS=-fcommon
made finally work the building of RPi.GPIO in pip3 install RPi.GPIO and then pip3 install zigpy-zigate==0.7.3 … now is time to see if I can add the zigbee integration on my HAC
