Unable to load component
Home-assistant unable to load component.i tried on both windows and raspberry pi but same result.It just find kodi running on computer. Cannot load vera hub, foscam camera even kodi running on same raspberry pi. I have tested the yaml file and there were no errors. Any ideas what i am missing. Just trying to start on home- assistant was using vera hub before.
You need to tell us at least the component that is not loading and the corrosponding part of your config file for that component. Also did you install all requirements via pip?
Greetings
Sorry about that. Got it working i was using V in caps in Vera Hub. Still learning …
Thanks for letting us now it’s working now and what the problem was tho! :slight_smile:
I was unable to connect to vera hub,cameras and kodi from hass installed on raspberry pi. Found the problem that i was using V and C in capital letter.
