I use the backup add-on. Restoring the previous version’s installation was easy. If you don’t have backups installed at your intallation, you may be stuck with 5.5.7.
What exactly didn’t work?
I don’t know where to look for the releases on github. A link to the release packages would be good to know.
That’s because you probably have automatic update enbled. Go to addons, select studio server and disable that.
I have auto-update disabled for all addons. I like to read changelog BEFORE i update anything. And even so i hit the mine a few times…
Apparently, this issue is related to an extension that VS Code server uses. It is "Home Assistant Config Helper v1.35.0 " as a built-in feature. The version listed here works and is part of the 5.5.6 release of VS Code Server. The most recent version of VS Code Server, 5.5.7, has “Home Assistant Config Helper v1.35.1” as the default, which is the most recent release.
Restoring the VS Code Server to 5.5.6 eliminates the problem. I do not know how to “downgrade” the helper in the VS Code server or even if that is possible, so the restoration mechanism works for me.
Well the restore was a complete drama, all kind of errors, in the log, no restore to v5.5.6, and a bricked Visual code server.
For me a restore was a bigger error than the error given all the time, but I tried it cause it did throw that error all the time, and it did no longer fill in entities with autofill as a consequence.
Still this error in V5.5.7 has now been mentioned several times here but not repaired, only got a message that the person who made the integration was not the one to fix this, so why there is this error and who will solve it is unclear?
Latest update, removed VCS completely, reinstalled it V5.5.7 error still there, did a roll back on the newly installed V5.5.7, which did work without the previous errors in the log, and now I am free of those weird remarks and have a running V5.5.6 without errors, plan to keep ignoring the future updates for a while till someone comes up with a sollution.
Dame it! Up to now I ignorred the issue but I have just noticed, that all files which show the error does not get tracked agymore. Basically the error occures to all the files once you open then up and once there is the issue it stops tracking.
I just finished a big recoding session where I put 90% of my frontend into yaml. At the same time I made a lot of changes to the general yaml code. By routine I wanted to save everything into Azure and notices that more than half of the code is missing. First I thought it is a git problem but now I am stuck and nothing works anymore!
If you are still running 5.5.7 maybe this will help.
If you go to the visual studio marketplace for the Home Assistant Config Helper where you can download previous versions of the Home Assistant Config Helper (V1.35.0) the format of the package is .vsix. This will open the overview page. Click on the Version History tab, choose V1.35.0 to download. Also, this problem has been reported as issue #2602
Once done, go to your VS Code Server click on the Extensions icon, then click on the ‘…’ in the upper right corner of the title bar of the extension pane to get at ‘Views And More Actions…’ then scroll down to ‘Install from VSIX…’ clicking on this option opens another pane where you now click on “choose local” to open a selection window on your machine. Navigate to the folder where the file is stored and continue.
In my installation of VS Code Server (5.5.6), the Helper is listed as 1.35.0, after having done all the above, without error/incident things are “normal”. That is, I do not get the error.
I was able to install the extension this way, but the studio still loads built-in 1.35.1. So I modified the version in extension.vsixmanifest and extension/package.json in the old extension to 1.35.2 (using 7-Zip and Notepad++) and then installed this “new” version.
So, today’s release of 5.6.0 of VS Code Server has, as the Home Assistant Config Helper V 1.35.0.
Upgraded and report the offensive error is not present. I avoided upgrading with the last release of VS Code Server because I didn’t want to deal with trying to downgrade the helper addon.
All good for now. Still have the auto-update feature turned off, and will check the dependency list before upgrading!
