I am getting confused as to when this problem happened but I cannot for the life of me understand what has gone wrong. I have been running version 0.56.1 since I first set up HA. No problems with the web-interface. Running SSL and password, working on mobiles and computer.
Today I upgraded to 0.57.2 and I have tried to remove cookies, run browser in private/inkognito mode etc but I am not able to log in. Some devices worked by cached credentials but as soon as I try to log in again I get failed login attempts in the log. I have tried to remove the SSL settings, remove password, reboot the docker (I run the docker image on Synology), reboot the NAS, reboot the router which does the port-forward, etc, etc. Same error now on all devices, unable to log in. Of course I also tried to downgrade to the old version 0.56.1 docker but no success (this is the one I run right now).
I am running mysql/mariaDB, found the database to be 1,2 GB, trunkated this to zero also. No change.
Here are some things I found in the log:
017-11-07 21:22:47 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 278, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 274, in aiohttp._http_parser.HttpParser.feed_data (aiohttp/_http_parser.c:4364)
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
If I open development console in Chrome to get some more debug info from the client side I find the following:
frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1 Uncaught TypeError: Cannot read property 'root' of undefined
at HTMLElement.forwardHostProp (frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1)
at Object.fn (frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1)
at a (frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1)
at e (frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1)
at HTMLTemplateElement.value (frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1)
at HTMLElement.value (frontend-2de1bde3b4a6c6c47dd95504fc098906.html:1)
I am loosing my mind over this crazy error. What the heck am I missing? #tired …
