I am running HAOS 14.1 and I am trying to create a sensor using command_line, that runs an ssh command to a target server to obtain a status.
I’ve done all the work of making SSH work between HA and the target server and from the HA terminal it works correctly:
I get an unknown value for sensor.test and I can see in the logs this error: Command failed (with return code 127): ssh -i /config/.ssh/id_ed25519 -o StrictHostKeyChecking=no [email protected] "\"C:/Program Files/Bitcoin/daemon/bitcoin-cli.exe\" -rpcuser=.. -rpcpassword=.. -rpcclienttimeout=35 -getinfo"
So I created two more sensors to test why ssh is not working:
That explains some things, but still doesn’t explain why the output of test5 is not captured.
test4 proved that the container has access to ssh and the simple ssh -V should have been shown.
What else am I missing?
Try adjusting your command formatting, your single-space indentation on the 2nd line looks like it may be adding an unintentional newline. If you want them joined into a single line it shouldn’t be indented:
Another possibility is the quoting, which can be tricky. You could try simplifying the command (less so than you’ve done), or try with some single quotes.
I really didn’t expect that ssh prints that information into stderr instead of stdout.
Thanks for pointing this out !
You had a good idea of trying something less complex so I did a single dir command:
This is the output on the terminal:
[core-ssh config]$ ssh -i /config/.ssh/id_ed25519 -o StrictHostKeyChecking=no [email protected] dir
Volume in drive C is Win 10
Volume Serial Number is 16A3-1394
Directory of C:\Users\oby
30/12/2024 14:42 <DIR> .
30/12/2024 14:42 <DIR> ..
30/12/2024 14:33 39 ${AUTH_KEY_FILE}
30/12/2024 14:42 95 %programdata%
16/01/2024 22:51 <DIR> .ms-ad
30/12/2024 14:52 <DIR> .ssh
But still unknown on the sensor defined like this:
Failed to set state for sensor.test6, fall back to unknown
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1227, in _async_write_ha_state
hass.states.async_set_internal(
entity_id,
...<5 lines>...
time_now,
File "/usr/src/homeassistant/homeassistant/core.py", line 2373, in async_set_internal
state = State(
entity_id,
...<8 lines>...
timestamp,
File "/usr/src/homeassistant/homeassistant/core.py", line 1817, in __init__
validate_state(state)
File "/usr/src/homeassistant/homeassistant/core.py", line 246, in validate_state
raise InvalidStateError(
...<2 lines>...
homeassistant.exceptions.InvalidStateError: Invalid state with length 1365. State max length is 255 characters.
The last thing points me to the actual error:
OK, so that tells me that the SSH command actually works.
Later edit, you were correct on the new line thing as well, I corrected that and now I got the correct output from ssh.
YEsssssssss thank you so much. I’ve spent countless hours to make this work and you pointed out the error in seconds.
