dittoI now have two SSD’s A samsung and an WD-Blue. Will wait for the patch
Same problem here.
Yellow POE with a Samsung 980 500GB NVMe SSD.
This is fixed in the upcoming Supervisor 2023.04.0, currently on the beta channel. If you’d like to use data disk today, you can join the beta channel and update the Supervisor to that version. See also Common Tasks - Operating System - Home Assistant.
Running the latest beta I can confirm I was able to move the datadisk successfully now!
Thanks.
How long would an update take to complete Its been over an hour now, and just the blue revolving circle to stare at
After updating the supervisor to 2023.04.0 it took less than 5 minutes before it rebooted and worked.
I have over 1000 devices and over 60 integrations.
If it’s taking that long; it’s not working.
Should the NVMe be formatted prior and if so, to ext4? I’m using HAOS on Odroid N2+.
