Hi from yesterday I have similar problem. I can not conncet to HA by DuckDNS and not working TTS with my google nest mni.
I found this in my log:
2022-10-19 09:12:55.840 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:12:55.844 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ical which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:12:55.846 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration salus which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:12:55.847 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration livebox which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:12:55.849 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:12:55.851 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:12:55.852 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-10-19 09:13:17.819 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-10-19 09:13:41.296 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform ipp is taking over 10 seconds.
2022-10-19 09:13:41.300 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Mi Air Purifier 3/3H' for xiaomi_miio integration not ready yet; Retrying in background
2022-10-19 09:13:41.309 ERROR (MainThread) [pyit600] Timeout while connecting to gateway:
2022-10-19 09:13:41.331 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.1.103' for yamaha_musiccast integration not ready yet; Retrying in background
2022-10-19 09:13:42.084 WARNING (MainThread) [homeassistant.components.vacuum] Setup of vacuum platform xiaomi_miio is taking over 10 seconds.
2022-10-19 09:13:47.687 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that uses deprecated `async_get_registry` to access device registry, use async_get instead. Please report issue to the custom integration author for salus using this method at custom_components/salus/__init__.py, line 68: device_registry = await dr.async_get_registry(hass)
2022-10-19 09:14:11.205 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: sensor.ical, esphome
2022-10-19 09:14:12.104 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for bluetooth-monitor-2 @ 192.168.1.105: Error connecting to ('192.168.1.105', 6053): [Errno 111] Connect call failed ('192.168.1.105', 6053)
2022-10-19 09:14:33.548 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/discovery_flow.py", line 71, in _async_start
await gather_with_concurrency(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 199, in gather_with_concurrency
return await gather(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 197, in sem_task
return await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 225, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data, init_done)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/yamaha_musiccast/config_flow.py", line 89, in async_step_ssdp
if not await MusicCastDevice.check_yamaha_ssdp(
File "/usr/local/lib/python3.10/site-packages/aiomusiccast/musiccast_device.py", line 87, in check_yamaha_ssdp
res = await client.get(location)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 559, in _request
await resp.start(conn)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 898, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.10/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
aiohttp.client_exceptions.ServerDisconnectedError: Server disconnected
2022-10-19 09:14:42.572 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:requestSync failed: 500
2022-10-19 09:15:07.982 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1191, in _sendfile_fallback
read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 514, in start
resp, reset = await task
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 460, in _handle_request
reset = await self.finish_response(request, resp, start_time)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 613, in finish_response
await prepare_meth(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_fileresponse.py", line 286, in prepare
return await self._sendfile(request, fobj, offset, count)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_fileresponse.py", line 99, in _sendfile
await loop.sendfile(transport, fobj, offset, count)
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1170, in sendfile
return await self._sendfile_fallback(transport, file,
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1200, in _sendfile_fallback
await proto.restore()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 268, in restore
self._transport.resume_reading()
File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 343, in resume_reading
self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'
2022-10-19 09:16:25.263 WARNING (SyncWorker_3) [pychromecast.controllers] Quick Play failed for https://xxxxxxxx.duckdns.org:8123/api/tts_proxy/c162b098c66c439ee14764538040ac4b63c9978d_pl_-_google_translate.mp3:audio/mpeg({})
2022-10-19 09:16:25.274 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall media_player.play_media (c:01GFQHK5REWD813GJHB5JA9BFG): entity_id=['media_player.nest_google'], announce=True, extra=, media_type=music, media_id=media-source://tts/google_translate?message=Cze%C5%9B%C4%87,+drzwi+wej%C5%9Bciowe+nie+s%C4%85+zamkni%C4%99te+na+zamek.+Zamknij+je+na+klucz.>
File "/usr/src/homeassistant/homeassistant/core.py", line 1756, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 207, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 749, in async_play_media
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/site-packages/pychromecast/quick_play.py", line 77, in quick_play
controller.quick_play(**data)
File "/usr/local/lib/python3.10/site-packages/pychromecast/controllers/media.py", line 547, in quick_play
raise PyChromecastError()
pychromecast.error.PyChromecastError
