Trying to open zigbee2mqtt web frontend in home assistant, but only get “Loading, please wait …”
Running hassio on Rapi 4.
`data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zb2mqtt
server: 'mqtt://core-mosquitto:1883'
user: mqttuser
password: xxxxxxxxxxxxx
serial:
port: /dev/ttyACM0
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
restartdelay: 1
initialdelay: 1
options: '-d -d'
log: false`
Logfile zigbee2mqtt
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
./run.sh: line 17: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2020-10-12T20:44:47: PM2 log: Launching in no daemon mode
2020-10-12T20:44:47: PM2 log: App [npm:0] starting in -fork mode-
2020-10-12T20:44:47: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.15.0
> node index.js
Zigbee2MQTT:info 2020-10-12 20:44:52: Logging to console and directory: '/share/zigbee2mqtt/log/2020-10-12.20-44-51' filename: log.txt
Zigbee2MQTT:info 2020-10-12 20:44:54: Starting Zigbee2MQTT version 1.15.0 (commit #1.15.0)
Zigbee2MQTT:info 2020-10-12 20:44:54: Starting zigbee-herdsman...
Zigbee2MQTT:info 2020-10-12 20:44:56: zigbee-herdsman started
Zigbee2MQTT:info 2020-10-12 20:44:56: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"}'
Zigbee2MQTT:info 2020-10-12 20:44:56: Currently 2 devices are joined:
Zigbee2MQTT:info 2020-10-12 20:44:56: 0x00158d00033de35f (0x00158d00033de35f): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
Zigbee2MQTT:info 2020-10-12 20:44:56: 0x00158d0002c63a1c (0x00158d0002c63a1c): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
Zigbee2MQTT:warn 2020-10-12 20:44:56: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2020-10-12 20:44:56: Allowing new devices to join.
Zigbee2MQTT:warn 2020-10-12 20:44:56: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2020-10-12 20:44:56: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2020-10-12 20:44:56: Started frontend on port 8099
Zigbee2MQTT:info 2020-10-12 20:44:56: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2020-10-12 20:44:57: Connected to MQTT server
Zigbee2MQTT:info 2020-10-12 20:44:57: MQTT publish: topic 'zb2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2020-10-12 20:44:57: MQTT publish: topic 'zb2mqtt/0x00158d00033de35f', payload '{"battery":86,"humidity":70.6,"linkquality":86,"pressure":1009.2,"temperature":15.79,"voltage":2975}'
Zigbee2MQTT:info 2020-10-12 20:44:57: MQTT publish: topic 'zb2mqtt/0x00158d0002c63a1c', payload '{"battery":97,"contact":true,"linkquality":39,"voltage":2995}'
Zigbee2MQTT:info 2020-10-12 20:44:57: MQTT publish: topic 'zb2mqtt/bridge/config', payload '{"commit":"1.15.0","coordinator":{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"},"log_level":"info","network":{"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":true,"version":"1.15.0"}'
Zigbee2MQTT:info 2020-10-12 20:44:57: MQTT publish: topic 'homeassistant/sensor/0x00158d00033de35f/temperature/config', payload '{"availability_topic":"zb2mqtt/bridge/state","device":{"identifiers":["zigbee2mqtt_0x00158d00033de35f"],"manufacturer":"Xiaomi","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","name":"0x00158d00033de35f","sw_version":"Zigbee2MQTT 1.15.0"},"device_class":"temperature","json_attributes_topic":"zb2mqtt/0x00158d00033de35f","name":"0x00158d00033de35f_temperature","state_topic":"zb2mqtt/0x00158d00033de35f","unique_id":"0x00158d00033de35f_temperature_zb2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}'
Zigbee2MQTT:info 2020-10-12 20:44:57: MQTT publish: topic 'homeassistant/sensor/0x00158d00033de35f/humidity/config', payload '{"availability_topic":"zb2mqtt/bridge/state","device":{"identifiers":["zigbee2mqtt_0x00158d00033de35f"],"manufacturer":"Xiaomi","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","name":"0x00158d00033de35f","sw_version":"Zigbee2MQTT 1.15.0"},"device_class":"humidity","json_attributes_topic":"zb2mqtt/0x00158d00033de35f","name":"0x00158d00033de35f_humidity","state_topic":"zb2mqtt/0x00158d00033de35f","unique_id":"0x00158d00033de35f_humidity_zb2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity }}"}'
I’m new to HA and have no idea how to fix it …
