Hi! After successfully migrating my zigbee network (30+ devices) from zha to z2mqtt. Everything is working fine (actually better than before), with the exception of a sonoff dongle p flashed as a router. It used to work ok in zha, but after migrating I haven’t been able to put it in pairing mode. Not sure if this is expected and I need to reflash it, or if I´m just missing how to put it back in pairing mode.
Any ideas? Has someone had a similar issue?
Best is to re-flash it.
There is new router firmware anyway
Thanks! Re-flashing made the trick. Working perfect again. By the way… loving Z2M
