I’m so close to make my thermostats behave the way I want. Now the following doesn’t work in the action part:
- data:
temperature: '{% if is_state(''binary_sensor.workday_sensor'',''on'') %} 22 {% else %} 21 {% endif %}'
entity_id: climate.neviweb130_climate_martin
service: climate.set_temperature
I get:
2020-01-12 09:11:10 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.a_test. Invalid data for call_service at pos 1: expected float for dictionary value @ data['temperature']
If I put only temperature: 22
, it works so I know the problem is there. The same string as a value for a message in notify works so the template syntax is fine.
I tried the following
temperature: '{% if is_state(''binary_sensor.workday_sensor'',''on'') %} {{22.0 | float}} {% else %} {{ 21.0 | float}} {% endif %}'
and
temperature: '{% if is_state(''binary_sensor.workday_sensor'',''on'') %} {{float(22.0)}} {% else %} {{ float(21.0)}} {% endif %}'
and even just temperature: '{{20.0 | float}}'
or temperature: '{{float (20.0)}}'
And nothing works
How do you pass template values as a float in action? I’m at lost, help please
