Unable to probe wemo at 192.168.1.xxx
Hi I’m using 8 Sonoff Touch switches flashed with Tasmota firmware… from sone days I receive continuous errors in my Hassio Home Assitaant log file… seem it is unable to finish starting service for wemo
I need help…
2018-03-05 18:52:54 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=49 from 2018-03-05 00:20:21.267111)
2018-03-05 18:53:18 WARNING (MainThread) [homeassistant.setup] Setup of wemo is taking over 10 seconds.
2018-03-05 18:53:21 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.84
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.86
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.87
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.85
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.91
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.81
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.82
2018-03-05 18:53:22 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.83
2018-03-05 18:53:23 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.84
2018-03-05 18:53:23 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.85
2018-03-05 18:53:23 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.86
2018-03-05 18:53:23 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.87
2018-03-05 18:53:23 WARNING (SyncWorker_17) [homeassistant.components.wemo] Unable to probe wemo at 192.168.1.91
Having similar problems as this, but they are actual wemo devices
Was having the same issues.
Just did current firmware update on all of my Wemo switches,
and everything is working better than ever.
Have
4 Wemo Mini Switches
1 Wemo Original Switch
2 Wemo Insight Switch
I disabled Belkin Wemo emulation to my Sonoff Touch switches flashed with Tasmota firmware and I solved the problem
I have been unable to get the wemo integration loaded so I wrote a quick mod to GitHub - szczys/wemoswitch-to-mqtt: MQTT control for a Wemo smart switch and loaded it as an MQTT light
Works fine
