Unable to re-pair zigbee dimmer switch after it dropped from network
I have two of the Leviton DG6HD-1BW Decora Smart Dimmer previously setup and working without any issue. I’m using a conbee ii stick running the latest firmware with ZHA integration.
Last night i noticed those two lights didnt turn off with my automation and realized the pairing light on both of them are flashing green (indicating in pairing mode). this is strange because i did not initiate the re-pair and they were working just fine.
I ended up deleting the device in home assistant and trying to re-add them after factory resetting (instruction from manual). After multiple tries I could not get them to add.
Today I decided to completely redo my zigbee network deleting the integration, .db file and zigbee storage. everything else in my previous zigbee network were discovered properly and gone through the setup without issue except the Levitons…
Anyone experiencing the same issue?
Same problem with my same dimmer switch. I haven’t messed with it. Worked great now not working.
