Unable to read file inside config folder (homeassistant supervised installed in DSM7)
Hello everyone, I have some issues about HA not able to read files under /config folder when I check the configuration.
The error is:
Error loading /config/configuration.yaml: in "/config/configuration.yaml", line 20, column 20: Unable to read file /config/SERVICE_ACCOUNT.JSON..
But I am positive the service_account.json is inside the /config folder
I’ve tried
chmod 644 /homeassistant/config/SERVICE_ACCOUNT.JSON
using SSH to my DSM 7 but it return
chmod: cannot access '/homeassistant/config/SERVICE_ACCOUNT.JSON': No such file or directory
So I tried
find / -name "SERVICE_ACCOUNT.JSON" 2>/dev/null
And it return
/volume2/docker/homeassistant/config/SERVICE_ACCOUNT.JSON
So I have no idea what’s going on.
Could it be a permission issue? or is the path not correct?
Some info:
Homeassistant is installed inside docker, and the docker folder inside my DSM 7 in volume 2 ( not the default volume, I changed it the volume 2, since my volume 1 is HDD and volume 2 is SSD.)
Any help is appreciated :grinning:
@hohaha045 Did you figure this out? I am having the same issue.
