Today i have tried to reinstall HASO ova13.2 qcow2 . I am stuck in a loop
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Setting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.10.2
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 13.2 / BootSlot A
[supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
[supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Cloning add-on https://github.com/music-assistant/home-assistant-addon repository
[supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
[supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
[supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
[supervisor.supervisor] Update Supervisor to version 2024.11.3
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2024.11.3.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
[supervisor.resolution.module] Create new issue update_failed - supervisor / None
[supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
[supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.11.1.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1/json: Not Found ("No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[04 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1/json: Not Found ("No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 1.088827ms, allowed: 44000/minute")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 780.999µs, allowed: 44000/minute")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec ```
Tried a few times still the above error , any ideas what the problem. I tried to update the recent Supervisor but received an error.
Any help would be appreciated.
