Unable to rename automation created from blueprint
If I create an automation from a blueprint, it lets me edit the name but it does not use that name. It just stays at “New Automation” after I click Save. If I edit the existing automation and change the name, I do not get a “Save” button.
If I create a normal automation without using a blueprint, I’m able to change its name just fine.
Why am I not able to rename my automation if I use a blueprint?
I see the same behavior trying to change the name in the UI. However, if I change the name in yaml and reload the Automations that does seem to work.
This was due to the following issue, which has been fixed as of 2022.3.5: the price of energy is not saved · Issue #67995 · home-assistant/core · GitHub
