Total noob here.
I keep getting Unable to resolve host hassbian
What do I need to do about that?
Total noob here.
Can you get to HA via IP:8123?
Assuming HA is up and running and you can access it by IP, next question would be what provides your name resolution?
I can access it by IP. I have no idea what provides the name resolution.
Whenever I run a script, I get that at the beginning and the end. I just used the Samba install script and the last things it wrote was
patching file smb.conf
sudo: unable to resolve host hassbian
Installation done.
If you have issues with this script, please contact @Landrash on gitter.im
Configuration is now available as a Samba share at \192.168.15.162\homeassistant
Thanks for the reply. I am lost.
type hostname
in terminal, whatās returned?
Perhaps hassbian.local
will work?
If your install is anything like mine, I had the same and had to edit the /etc/hosts file and correct one of the lines. To be honest it was a little while ago when I installed and I cant remember exactly, but either the name was wrong or the IP address was wrong, once updated those messages went away for me.
I now have two IP4 entries in the hosts file :
127.0.0.1 localhost
127.0.1.1 HASS
as yours is talking about āhassbianā I guess you could try:
127.0.1.1 hassbian
I need to meet the minimum characters to when I type hostname I get
hassbian
noob here: can you give me a link that would walk me through that?
Perhaps . . . .I donāt know where I would change it. I have no idea where it is getting the hostname from.
I restarted and now I am having the same problem I have had in the past. After restarting it says it canāt find the host. It asks for usr & pw then it wonāt let me do anything else.
All i get is the error unable to resolve host hassbian
If I try to run anything it wonāt accept my password.
Just in case anyone tried to work on this, I am reinstalling using noob instead of Hassbian. I will see if that gives me different results.
Honestly, you would just need to add:
127.0.1.1 hassbian`
To the /etc/hosts file to get rid of that. The easiest way would be to do:
sudo nano /etc/hosts
And then make the changeā¦`
So I tried to reinstall HA the old way and simply could not make it work. That took a really, really, long time and it did not actually work.
I reinstalled Hassbian, ioaded lots of stuff, got that error again, used the steps you posted. did them wrong at least twice, did it right, then could not get it to run.
Lots and lots of searching, went through the log file, found i had something wrong in the configuration.yaml and simply deleted the things I tried to get HA to do, and finally it works!
I even got the autostart to work. I feel accomplished even though I cant get HA to actually do anything yet. I do have it running though.
edit: I would mark this solved, but donāt know how or if this forum uses that.
This is really all that you need to do, if you googled āUnable to resolve hostā you wouldāve found hundreds of results all saying the same thing as itās nothing to do with HA itself.
I know because thatās what i did when I got it!!!
Good for you.
Lol, perhaps if you took peopleās advice you wouldnāt waste yours and others time
Thereās always one on a forum, guess you are it.
I originally had more than one problem. That confounded the single answer you have come with a day late.
I fixed the first problem and realized the resolve host was isolated. I could not log back into pi to fix the host file, but it took me hours to realize that.
After I reinstalled pi for the fourth time, since I have never done anything in Xnix before, I tried again and resolved the first problem but the second problem, unable to resolve host hassbian, represented it self.
I updated my original problem because I did not do anything to cause this problem and still think it might be a bug.
BendedArrow was nice enough to post a solution since I had no idea what
Please post the contents of /etc/hostname and /etc/hosts.
meant.
I had no idea how to do that. So he rescued me. Sorry that upsets you. Tell you what, I will give you a little cookie and click your heart since that seems to be what you are fishing for.
Please be nice and donāt taunt others. Your posts have been flagged by others
Hi all
I too was getting the unable to resolve host issue, and I attempted to follow the advice of inserting the line
127.0.1.1 hassbian
While I was editing the hosts file my laptop froze, and killed the putty connection.
When I terminalled back in the hosts file is now blank. Can someone post what the hosts file should be for the hassbian version of homeassistant.
This is the deafult hosts file on my hassbian install.
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 raspberrypi
