Unable to run motor using esp32
Hi. Am trying to control my motors using esp 32 on pwm but not working. Please help. Here is my code
// Motor A
int motor1Pin1 = 16;
int motor1Pin2 = 17;
int enable1Pin = 21;
// Setting PWM properties
const int freq = 30000;
const int pwmChannel = 0;
const int resolution = 8;
int dutyCycle = 200;
void setup() {
  // sets the pins as outputs:
  pinMode(motor1Pin1, OUTPUT);
  pinMode(motor1Pin2, OUTPUT);
  pinMode(enable1Pin, OUTPUT);
  // configure LED PWM functionalitites
  ledcSetup(pwmChannel, freq, resolution);
  // attach the channel to the GPIO to be controlled
  ledcAttachPin(enable1Pin, pwmChannel);
  Serial.begin(115200);
  // testing
  Serial.print("Testing DC Motor...");
void loop() {
  // Move the DC motor forward at maximum speed
  Serial.println("Moving Forward");
  digitalWrite(motor1Pin1, LOW);
  digitalWrite(motor1Pin2, HIGH);
  delay(2000);
  // Stop the DC motor
  Serial.println("Motor stopped");
  digitalWrite(motor1Pin2, LOW);
  delay(1000);
  // Move DC motor backwards at maximum speed
  Serial.println("Moving Backwards");
  digitalWrite(motor1Pin1, HIGH);
  delay(2000);
  delay(1000);
  // Move DC motor forward with increasing speed
  while (dutyCycle <= 255){
    ledcWrite(pwmChannel, dutyCycle);
    Serial.print("Forward with duty cycle: ");
    Serial.println(dutyCycle);
    dutyCycle = dutyCycle + 5;
    delay(500);
  dutyCycle = 200;
This does not seem to have anything to do with esphome!
yeah, definitely not ESPHome code. It looks like arduino to me.
Moved.
