DarrenHA
(Darren)
December 4, 2022, 4:28am
1
I appear to be having issues trying to save automations. I’m new to creating home assistant automations. Each time I create one and hit save, I receive an error message in the home assistant log and the automation doesn’t seem to save.
Below is a copy of the error:
Invalid config for [automation]: expected dictionary. Got OrderedDict([(‘default_config’, {}), (‘tts’, [OrderedDict([(‘platform’, ‘google_translate’)])]), (‘group’, {}), (‘automation’, ‘include automations.yaml’), (‘script’, {}), (‘http’, OrderedDict([(‘ip_ban_enabled’, True), (‘login_attempts_threshold’, 3), (‘cors_allowed_origins’, [‘https://cast.home-assistant.io ’]), (‘ssl_profile’, ‘modern’), (‘server_port’, 8123)]))]). (See ?, line ?).
Any help would be appreciated. I have tried troubleshooting and searching the forms, and I can’t seem to find a solution.
Could you show us the yaml for your automation. Be sure to use the code formatting in your message.
DarrenHA
(Darren)
December 5, 2022, 12:10am
3
Please see attached:
- id: '1670126602739'
alias: Camera Automation
description: ''
- platform: device
device_id: b167284684be313992c29ef9e68aaceb
domain: device_tracker
entity_id: device_tracker.samsung
type: leaves
zone: zone.home
condition: []
- type: turn_on
device_id: f3c1a2eea42075ea0b5abe675a503a18
entity_id: switch.living_room_camera_power
domain: switch
- type: turn_on
device_id: 42885047c075898016569b817a07ad1c
entity_id: switch.lizard_room_camera_power
domain: switch
mode: single
- id: '1670127043459'
description: Automatically torn on webcams when leaving home zone
- platform: device
type: leaves
zone: zone.home_2
condition: []
- type: turn_on
domain: switch
mode: single
The code you have provided seems to contain two automations.
Are you creating your automation using the automation editor UI or, are you editing the yaml file directly?
DarrenHA
(Darren)
December 5, 2022, 10:48pm
6
I’m using the automation editor UI. When I save the automation, it doesn’t show up on the automations list, and the logs notify me of the above error. I assume the reason why the automation is copied twice is because I’ve tried to create automation twice.
