Unable to Send Photo via Telegram Bot
I have successfully setup the Telegram integration and created a bot that sends a picture from my doorbell camera (I am using the Amcrest integration for my AD410 doorbell) when motion is detected. I have found a issue/bug when using different camera sources:
When the snapshot is taken with the main camera, I get an error (see below).
When I setup a camera proxy and use it, the picture is sent successfully.
* Error sending photo: Image_process_failed. Args: (), kwargs: {'chat_id': 441726636, 'photo': <_io.BufferedReader name='/config/www/tmp/doorbell.jpg'>, 'caption': None, 'disable_notification': False, 'reply_markup': None, 'timeout': None, 'parse_mode': 'Markdown'}
Any idea what is going wrong here? The log is not very helpful.
My automation (this camera entity results in the error above):
alias: Doorbell Motion (Telegram)
description: ''
  - platform: state
    entity_id:
      - binary_sensor.doorbell_motion_detected
    to: 'on'
condition:
  - condition: template
    value_template: >-
      {{ (as_timestamp(now()) -
      as_timestamp(states.automation.doorbell_motion_telegram.attributes.last_triggered
      | default(0)) | int > 60)}}
  - condition: time
    before: '22:00:00'
    after: '06:00:00'
  - service: camera.snapshot
      filename: /config/www/tmp/doorbell.jpg
      entity_id:
        - camera.doorbell
  - service: notify.telegramgroup
      message: Motion Detected
        photo:
          - file: /config/www/tmp/doorbell.jpg
My automation (this camera entity results in a successful notification):
description: ''
  - platform: state
    entity_id:
    to: 'on'
condition:
    value_template: >-
  - condition: time
    before: '22:00:00'
    after: '06:00:00'
      entity_id:
        - camera.doorbell_cropped
        photo:
You may need to allow some time for the file to be created. Try:
      entity_id:
        - camera.doorbell
  - delay: 2
        photo:
Also does camera.doorbell have a still image URL defined in its config?
Thanks, I will try it. No URL is defined.
