I created a widget to turn on a scene. Ever since I’ve added SSL support it started to behave weird:
It will fail with Unable to send service call every time I click it, until I open the app. Then it will work for a short period until again it will fail until I open the app (see gif below).
I’ve tried to remove the widget and recreate it and it didn’t work.
Any idea how to fix it?
I’m getting CertPathValidatorException error due to SSL. Is there a specific way to add the certificate on Android devices?
04-05 19:04:25.504 7016 7016 E ButtonWidget: Could not send service call.
04-05 19:04:25.504 7016 7016 E ButtonWidget: io.homeassistant.companion.android.common.data.integration.IntegrationException: javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
04-05 19:04:25.504 7016 7016 E ButtonWidget: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.callService(IntegrationRepositoryImpl.kt:239)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$callService$1.invokeSuspend(Unknown Source:15)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.os.Handler.handleCallback(Handler.java:938)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.os.Handler.dispatchMessage(Handler.java:99)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.os.Looper.loopOnce(Looper.java:201)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.os.Looper.loop(Looper.java:288)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.app.ActivityThread.main(ActivityThread.java:7870)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at java.lang.reflect.Method.invoke(Native Method)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:548)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1003)
04-05 19:04:25.504 7016 7016 E ButtonWidget: Caused by: javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.SSLUtils.toSSLHandshakeException(SSLUtils.java:363)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.convertException(ConscryptEngine.java:1134)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.readPlaintextData(ConscryptEngine.java:1089)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:876)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:747)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:712)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.processDataFromSocket(ConscryptEngineSocket.java:858)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.access$100(ConscryptEngineSocket.java:731)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngineSocket.doHandshake(ConscryptEngineSocket.java:241)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngineSocket.startHandshake(ConscryptEngineSocket.java:220)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.kt:379)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.kt:337)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:209)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at java.lang.Thread.run(Thread.java:920)
04-05 19:04:25.504 7016 7016 E ButtonWidget: Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.TrustManagerImpl.checkTrustedRecursive(TrustManagerImpl.java:656)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:505)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:425)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.TrustManagerImpl.getTrustedChainForServer(TrustManagerImpl.java:353)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.security.net.config.NetworkSecurityTrustManager.checkServerTrusted(NetworkSecurityTrustManager.java:94)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at android.security.net.config.RootTrustManager.checkServerTrusted(RootTrustManager.java:90)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngineSocket$2.checkServerTrusted(ConscryptEngineSocket.java:163)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.Platform.checkServerTrusted(Platform.java:255)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.verifyCertificateChain(ConscryptEngine.java:1638)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.NativeCrypto.ENGINE_SSL_read_direct(Native Method)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.NativeSsl.readDirectByteBuffer(NativeSsl.java:569)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.readPlaintextDataDirect(ConscryptEngine.java:1095)
04-05 19:04:25.504 7016 7016 E ButtonWidget: at com.android.org.conscrypt.ConscryptEngine.readPlaintextData(ConscryptEngine.java:1079)
04-05 19:04:25.504 7016 7016 E ButtonWidget: ... 27 more
04-05 19:04:25.504 7016 7016 E ButtonWidget: Caused by: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
04-05 19:04:25.504 7016 7016 E ButtonWidget: ... 40 more
You mean like a self signed certificate? You should be able to import that
If this is supposed to be a valid certificate then you may want to try a different provider as Android can be picky about it. The trust anchor error suggests that may be the case here.
