I’ve got a light that I can control with HASS. However if the light is switched outside of HA the state in HASS is out of synch. I’ve tried to create a webhook that will change the HASS state but it isn’t working.
Using Dev Tools >States I can set the state to any value, but ‘on’ and ‘off’ change the UI to a lamp on /off icon.
I am using curl to trigger this at the moment and getting 200 OK message returned, but I cannot see anything in the logs to hep debug.
… any pointers please.
TIA
- alias: set light state
description: "update status on webhook message"
- platform: webhook
webhook_id: familyrm-light-star
condition: []
entity_id: light.familyrm_light_star
state: "{{ trigger.json.state }}"
and the curl with response following
curl --header "Content-Type: application/json" -i --request POST --data '{"state":"on"}' http://192.168.0.60:8123/api/webhook/familyrm-light-star
HTTP/1.1 200 OK
Content-Length: 0
Content-Type: application/octet-stream
Date: Fri, 19 Aug 2022 13:11:07 GMT
Server: Python/3.10 aiohttp/3.8.1
Ok thanks will look at action types…
I like the template for selecting the service, neat!
I don’t want to trigger the service light…on/off as that will send a rest command back to set the state, so could end up in a loop.
Hopefully there is something where I can just set the state of the entity as it doesn’t have a device as a parent… learning all these hass concepts as I go so that might not be true, it could have been allocated one…will look later
Thanks!
Found some new action types eg in automations here, but nothing for state.
My entities have a platform (light) but not a device, AFAICT
The Hass Entities python script looks like it does what I want, many thanks for the steer.
