I have some Zooz ZEN27 dimmer switches, and having trouble setting some of the config parameters - seems to be those parameters that are numbers. When I try to set the parameter on the zwave control panel - it seems to go thru, but the value doesn’t take.
I also tried setting the parameter via a data template; where I specify “size”: 1, however even when I do that, the command seems to be sent with size: 2.
Appreciate any help with diagnosing this. Thanks!
2019-03-05 13:19:23.485 Info, Node011, Value::Set - COMMAND_CLASS_CONFIGURATION - Ramp Rate Control - 9 - 1 - 5
2019-03-05 13:19:23.485 Info, Node011, Configuration::Set - Parameter=9, Value=5 Size=2
2019-03-05 13:19:23.485 Detail, Node011, Queuing (Send) ConfigurationCmd_Set (Node=11): 0x01, 0x0d, 0x00, 0x13, 0x0b, 0x06, 0x70, 0x04, 0x09, 0x02, 0x00, 0x05, 0x25, 0x9c, 0x2f
2019-03-05 13:19:23.485 Detail, Node011, Queuing (Send) ConfigurationCmd_Get (Node=11): 0x01, 0x0a, 0x00, 0x13, 0x0b, 0x03, 0x70, 0x05, 0x09, 0x25, 0x9d, 0x2a
2019-03-05 13:19:23.486 Detail,
2019-03-05 13:19:23.486 Info, Node011, Sending (Send) message (Callback ID=0x9c, Expected Reply=0x13) - ConfigurationCmd_Set (Node=11): 0x01, 0x0d, 0x00, 0x13, 0x0b, 0x06, 0x70, 0x04, 0x09, 0x02, 0x00, 0x05, 0x25, 0x9c, 0x2f
2019-03-05 13:19:23.494 Detail, Node011, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-03-05 13:19:23.494 Detail, Node011, ZW_SEND_DATA delivered to Z-Wave stack
2019-03-05 13:19:23.511 Detail, Node011, Received: 0x01, 0x07, 0x00, 0x13, 0x9c, 0x00, 0x00, 0x02, 0x75
2019-03-05 13:19:23.515 Detail, Node011, ZW_SEND_DATA Request with callback ID 0x9c received (expected 0x9c)
2019-03-05 13:19:23.516 Info, Node011, Request RTT 29 Average Request RTT 27
2019-03-05 13:19:23.516 Detail, Expected callbackId was received
2019-03-05 13:19:23.516 Detail, Expected reply was received
2019-03-05 13:19:23.516 Detail, Message transaction complete
2019-03-05 13:19:23.516 Detail, Node011, Removing current message
2019-03-05 13:19:23.516 Info, Node011, Sending (Send) message (Callback ID=0x9d, Expected Reply=0x04) - ConfigurationCmd_Get (Node=11): 0x01, 0x0a, 0x00, 0x13, 0x0b, 0x03, 0x70, 0x05, 0x09, 0x25, 0x9d, 0x2a
2019-03-05 13:19:23.526 Detail, Node011, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-03-05 13:19:23.535 Detail, Node011, ZW_SEND_DATA delivered to Z-Wave stack
2019-03-05 13:19:23.543 Detail, Node011, Received: 0x01, 0x07, 0x00, 0x13, 0x9d, 0x00, 0x00, 0x02, 0x74
2019-03-05 13:19:23.543 Detail, Node011, ZW_SEND_DATA Request with callback ID 0x9d received (expected 0x9d)
2019-03-05 13:19:23.543 Info, Node011, Request RTT 25 Average Request RTT 26
2019-03-05 13:19:23.543 Detail, Expected callbackId was received
2019-03-05 13:19:23.562 Detail, Node011, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0b, 0x05, 0x70, 0x06, 0x09, 0x01, 0x01, 0x81
2019-03-05 13:19:23.562 Info, Node011, Response RTT 44 Average Response RTT 44
2019-03-05 13:19:23.562 Detail, Node011, Refreshed Value: old value=1, new value=1, type=short
2019-03-05 13:19:23.562 Detail, Node011, Changes to this value are not verified
2019-03-05 13:19:23.562 Info, Node011, Received Configuration report: Parameter=9, Value=1
2019-03-05 13:19:23.562 Detail, Node011, Expected reply and command class was received
2019-03-05 13:19:23.562 Detail, Node011, Message transaction complete
2019-03-05 13:19:23.563 Detail,
2019-03-05 13:19:23.563 Detail, Node011, Removing current message
2019-03-05 13:19:23.563 Detail, Node011, Notification: ValueChanged
