Ever since some update I’ve been getting this error and my presence detection automations haven’t been working. I read the documentation and it seems known devices is being phased out.
How do I go about using owntracks, Bluetooth device recognition and ip recognition without trackers?
You configure owntracks via the integrations section in the UI. Bluetooth and ping are not affected by this change.
What do you mean they are not affected? Without device_tracker nmap_tracker stopped working and so did bluetooth_tracker, using owntracks via integration also forces me to use http instead of mqtt
I don’t know how else to say it, Bluetooth and other such trackers haven’t changed. I use owntracks, ping and Bluetooth and it all works fine. If yours isn’t working there is something else wrong.
You need to read the documentation and set up your device trackers again.
