Unable to set up Google Assistant integration - Google Actions Sunset
Hey there,
New to home assistant, have most of my house configured with it now using a Raspberry Pi 5 to run it. One issue I am running into is connecting to my Google Home to run custom actions through Home Assistant. I tried to go through the Google Assistant integration manual setup, but it seems that Google Actions are now deprecated (sunset). I can’t seem to find much online about anyone else dealing with this issue, so I am stuck. Is the only way to set up Google Assistant to Home Assistant now to use Home Assistant Cloud? Or is there a new way to do this that isn’t mentioned on the Google Assistant integration setup page.
Additional Info: I was able to connect to my Google Home using the Google Assistant SDK, but that seems to only allow me to broadcast & run actions on the Google Home. This integration doesn’t allow me to ask Google to perform actions, which is what I want.
Would appreciate some help :slight_smile:
I have the same problem :frowning:
look at this post, it has step by step instructions, because the homeassistant doku is outdated:
Github Step by Step
