My apologies if this maybe already been covered, however couldn’t find anything in the forums.
I have a MQTT topic “/feeds/temperature” (private MQTT broker) where some sensor temperature data is being published. Having setup a standard MQTT sensor in HASS, it doesn’t show anything though.
The HASS log shows the feed to be received successfully:
Thanks for the feedback! I figured it out eventually… My own mistake
In the configuration my value template was set as “{{ value.x }}”. Changing this to “{{ float(value) / 100 }}” solved the issue. (I had to cast to float because the sent value is an int value multiplied by 100).
It works perfectly! Appreciate all the work put in this great piece of software
