I upgraded my hass.io installation on a pi2 from version 0.65.6 to 0.66.1.
After the upgrade the system did not come online again.
I logged in via the debug console and found the following error:
root@hassio:/mnt/boot# journalctl -f -u resin-supervisor.service -- Logs begin at Sun 2017-09-17 21:25:34 UTC. -- Apr 04 16:04:23 hassio systemd[1]: Dependency failed for Resin supervisor. Apr 04 16:04:23 hassio systemd[1]: resin-supervisor.service: Job resin-supervisor.service/start failed with result 'dependency'.
I looked a bit further with journalctl -xe and found the following error:
Apr 04 15:41:42 hassio kernel[645]: [[0;1;39m[ 12.069538] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.[[0m
I fixed this by running fsck. Unfortunatly, after a reboot, it still did not get online.
I now found the following error:
Apr 04 16:08:10 hassio systemd[1]: Starting Docker Socket for the API. Apr 04 16:08:10 hassio systemd[1]: Listening on Docker Socket for the API. Apr 04 16:08:10 hassio systemd[1]: Starting Docker Application Container Engine... Apr 04 16:08:10 hassio dockerd[1016]: time="2018-04-04T16:08:10.829569557Z" level=info msg="libcontainerd: new containerd process, pid: 1025" Apr 04 16:08:12 hassio dockerd[1016]: Error starting daemon: error while opening volume store metadata database: invalid database Apr 04 16:08:12 hassio systemd[1]: [[0;1;39mdocker.service: Main process exited, code=exited, status=1/FAILURE[[0m Apr 04 16:08:12 hassio systemd[1]: [[0;1;31mFailed to start Docker Application Container Engine.[[0m Apr 04 16:08:12 hassio systemd[1]: [[0;1;39mdocker.service: Unit entered failed state.[[0m Apr 04 16:08:12 hassio systemd[1]: [[0;1;39mdocker.service: Failed with result 'exit-code'.[[0m Apr 04 16:08:12 hassio systemd[1]: docker.service: Service hold-off time over, scheduling restart. Apr 04 16:08:12 hassio systemd[1]: Stopped Docker Application Container Engine. Apr 04 16:08:12 hassio systemd[1]: Closed Docker Socket for the API. Apr 04 16:08:12 hassio systemd[1]: Stopping Docker Socket for the API.
I seem to have enough space on my SD card:
root@hassio:/mnt/boot# df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 481M 0 481M 0% /dev /dev/mmcblk0p3 295M 217M 62M 78% / /dev/disk/by-label/resin-state 19M 200K 17M 2% /mnt/state tmpfs 487M 0 487M 0% /dev/shm tmpfs 487M 5.6M 481M 2% /run tmpfs 487M 0 487M 0% /sys/fs/cgroup tmpfs 487M 0 487M 0% /tmp tmpfs 487M 40K 487M 1% /var/volatile /dev/mmcblk0p1 40M 26M 15M 63% /mnt/boot /dev/mmcblk0p6 28G 8.2G 18G 32% /mnt/data
Need help! Any ideas?
