After a simple homeassistant restart like many other restarts I’ve done before, the homeassistant container exits some seconds right after its start. The log shows this:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[23:15:05] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 350, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 324, in main
args = get_arguments()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 80, in get_arguments
import homeassistant.config as config_util
File "/usr/src/homeassistant/homeassistant/config.py", line 12, in <module>
import voluptuous as vol
File "/usr/local/lib/python3.7/site-packages/voluptuous/__init__.py", line 4, in <module>
from voluptuous.validators import *
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 857, in get_code
File "<frozen importlib._bootstrap_external>", line 525, in _compile_bytecode
ValueError: bad marshal data (invalid reference)
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Any suggestion to get this running again would be appreciated. Thank you.
