Unable to start OZWCP on RPi AiO clean install .38.2
Starting this thread for anyone else who is experiencing this issue as well. I’ve raised an issue on the tracker.
https://github.com/home-assistant/home-assistant/issues/5968
If anyone has advice it’ll be very much appreciated.
Mentioning @xpress142 and @Tinkerer because there was a discussion started on an old thread.
Thx. I’m to late: I’ve opened also a tread.
The issue was moved to the right tracker:
https://github.com/home-assistant/fabric-home-assistant/issues/46
Roddie saved the day!!! TY!
Thanks for posting this here. Wouldn’t have seen it otherwise.
Following the tutorial after
Open the Makefile and find the following line:
OPENZWAVE := ../
LIBMICROHTTPD := -lmicrohttpd
Change it to:
OPENZWAVE := ../open-zwave
LIBMICROHTTPD := /usr/local/lib/libmicrohttpd.a
Build ozwcp
make
I get this
pi@raspberrypi:~/open-zwave-control-panel $ make
g++ -c -Wall -Wno-unknown-pragmas -Wno-inline -Wno-format -g -DDEBUG -ggdb -O0 -I ../open-zwave//cpp/src -I ../open-zwave//cpp/src/command_classes/ -I ../open-zwave//cpp/src/value_classes/ -I ../open-zwave//cpp/src/platform/ -I ../open-zwave//cpp/src/platform/unix -I ../open-zwave//cpp/tinyxml/ -I /usr/local/include/ -o ozwcp.o ozwcp.cpp
g++ -c -Wall -Wno-unknown-pragmas -Wno-inline -Wno-format -g -DDEBUG -ggdb -O0 -I ../open-zwave//cpp/src -I ../open-zwave//cpp/src/command_classes/ -I ../open-zwave//cpp/src/value_classes/ -I ../open-zwave//cpp/src/platform/ -I ../open-zwave//cpp/src/platform/unix -I ../open-zwave//cpp/tinyxml/ -I /usr/local/include/ -o webserver.o webserver.cpp
g++ -c -Wall -Wno-unknown-pragmas -Wno-inline -Wno-format -g -DDEBUG -ggdb -O0 -I ../open-zwave//cpp/src -I ../open-zwave//cpp/src/command_classes/ -I ../open-zwave//cpp/src/value_classes/ -I ../open-zwave//cpp/src/platform/ -I ../open-zwave//cpp/src/platform/unix -I ../open-zwave//cpp/tinyxml/ -I /usr/local/include/ -o zwavelib.o zwavelib.cpp
g++ -o ozwcp -g ozwcp.o webserver.o zwavelib.o ../open-zwave//libopenzwave.a  /usr/local/lib/libmicrohttpd.a -pthread -framework IOKit -framework CoreFoundation  -lresolv
g++: error: IOKit: No such file or directory
g++: error: CoreFoundation: No such file or directory
g++: error: unrecognized command line option ‘-framework’
Makefile:71: recipe for target 'ozwcp' failed
make: *** [ozwcp] Error 1
