Unable to start zigbeemqtt after upgrade to 2023.5.4
After I upgrade to 2023.5.4, the zigbeemqtt add on is unable to start up. This is the error and my coordinator connected to the usb. The path has not changed. What is the error saying??
error:
[07:35:25] INFO: Preparing to start...
[07:35:26] INFO: Socat not enabled
[07:35:26] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:error 2023-05-25 07:35:48: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-05-25 07:35:48: Failed to start zigbee
Zigbee2MQTT:error 2023-05-25 07:35:48: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-05-25 07:35:48: Exiting...
Zigbee2MQTT:error 2023-05-25 07:35:48: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:58:27)
    at Controller.start (/app/lib/controller.ts:101:27)
    at start (/app/index.js:107:5)
coordinator:
DEVLINKS: >-
  /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
  /dev/serial/by-path/pci-0000:00:14.0-usb-0:3:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/ttyUSB0/tty/ttyUSB0
ID_BUS: usb
ID_MODEL: USB_Serial
ID_MODEL_ENC: USB\x20Serial
ID_MODEL_ID: '7523'
ID_PATH: pci-0000:00:14.0-usb-0:3:1.0
ID_PATH_TAG: pci-0000_00_14_0-usb-0_3_1_0
ID_REVISION: '0264'
ID_SERIAL: 1a86_USB_Serial
ID_TYPE: generic
ID_USB_DRIVER: ch341
ID_USB_INTERFACES: ':ff0102:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: USB_Serial
ID_USB_MODEL_ENC: USB\x20Serial
ID_USB_MODEL_ID: '7523'
ID_USB_REVISION: '0264'
ID_USB_SERIAL: 1a86_USB_Serial
ID_USB_TYPE: generic
ID_USB_VENDOR: 1a86
ID_USB_VENDOR_ENC: 1a86
ID_USB_VENDOR_ID: 1a86
ID_VENDOR: 1a86
ID_VENDOR_ENC: 1a86
ID_VENDOR_ID: 1a86
MAJOR: '188'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '1301159928'
Does this help? Zigbee2MQTT fails to start | Zigbee2MQTT
You should specify this using “serial by id” (search the forum). The dev/tty/ link can change.
