After upgrading to .86 I removed my old lovelace.yaml and planned to go “full Lovelace”. But when I want configure the ui to take controll over Lovelace I get a popup with the message: Saving failed: Not supported. Same thing happens in all browsers. So im stuck with the default Lovelace. Fixable?
That would be indentation/code errors in your migrated Lovelace code I think. I know that if I tried to edit Lovelace via the GUI and there were errors somewhere, that was the error that would come up
But there is no lovelace code, I removed lovelace.yaml before upgrading. So this is vanilla lovelace created by hass.io. And I get no config errors.
make sure you remove
lovelace:
mode: yaml
from configuration.yaml
Yes figured it out myself just now Its always the simple things. Hope this can help someone else in the future.
It did help, thanks for this!
but then where is the ui-lovelace.yaml, it should be in the config folder ?
I’m having the same problem; if I delete
lovelace:
mode: yaml
Then I get "The edit UI is not available when in YAML mode.
