Unable to update 2022.12 and add-ons
I want to update HA 2022.12.0 to 2022.12.3, but I get the message:
… blocked from execution, system is not healthy - setup
I also get such message when I try to update an add-on. HA works fine, no problems. Also a restart didn’t help and no errors related to this found in the logging.
This is what the log is showing:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:305
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 20:01:52 (2 occurrences)
Last logged: 20:01:57
[547800011184] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 303, in async_install
    await async_update_core(self.hass, version=version, backup=backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1745, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1782, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 943, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 305, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
Any ideas?
Fixed by hardware power down/up
I have a similar problem. I can’t update from 12.1 either OS or core or any addon.
The supervisor writes the following:
2024-05-30 20:19:05.232 ERROR (MainThread) [supervisor.os.manager] Home Assistant Operating System update failed with: Installation error: Failed updating slot kernel.1: Opening output device /dev/disk/by-partlabel/hassos-kernel1 failed: Device or resource busy
How to fixed?
