Unable to update Add-ons
Hi I have trouble to update the add-ons since some versions currently I am running 2024.9.1. I have to reboot the complete system to get the update function back until the next time.
This is the error message in the supervisor log:
2024-09-07 20:22:36.811 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140631092281008] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 168, in async_install
    await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 57, in _wrapper
    data = await funct(*argv, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 134, in async_update_addon
    return await hassio.send_command(
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 599, in send_command
    raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: Another job is running for job group addon_45df7312_zigbee2mqtt
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2761, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2804, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 996, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1068, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 458, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 170, in async_install
    raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating Zigbee2MQTT: Another job is running for job group addon_45df7312_zigbee2mqtt
Same error here
Any fix for this?
In case it helps: I traced a similar symptom to network MTU problems
Trying to update my new Inspelning IKEA plugs, same error occours. Updates raises to ~6%, then fails. On one attempt iI got 17%, still not enough :slight_smile:
Reboot of HA, unplugging (the plugs) etc didn’t change the behaviour.
