Forgive me if I’m posting this in the incorrect category.
I have a number of Aeotec ZWA039 aerQ sensors which all have firmware version 2.1.1.
I have now tried to update these but unfortunately it fails. Looking at the Z-Wave JS log I can see the following:
2024-05-30T18:16:23.188Z CNTRLR » [Node 039] Sending firmware fragment 4772 / 4778
2024-05-30T18:16:23.240Z CNTRLR » [Node 039] Sending firmware fragment 4773 / 4778
2024-05-30T18:16:23.292Z CNTRLR » [Node 039] Sending firmware fragment 4774 / 4778
2024-05-30T18:16:23.346Z CNTRLR » [Node 039] Sending firmware fragment 4775 / 4778
2024-05-30T18:16:23.397Z CNTRLR » [Node 039] Sending firmware fragment 4776 / 4778
2024-05-30T18:16:23.450Z CNTRLR » [Node 039] Sending firmware fragment 4777 / 4778
2024-05-30T18:16:23.501Z CNTRLR » [Node 039] Sending firmware fragment 4778 / 4778
2024-05-30T18:16:24.603Z CNTRLR « [Node 039] received wakeup notification
2024-05-30T18:21:23.538Z CNTRLR [Node 039] The node did not acknowledge the completed update
2024-05-30T18:21:23.539Z CNTRLR « [Node 039] Firmware update (part 1 / 1) failed with status Error_Timeout
I can repeat the update process over and over again, but it always fails. The sensor seems to work, but the battery reporting is not that great. (That is also reported as an issue)
I have also visited the support page where I downloaded the gbl file to try to update the sensor using the “Device Info | Update” possibility. However the result is unfortunately the same.
If anyone has any tips that I could try, that would be very appreciated.
I’ve only updated my ZWA039-A once, and when I did, I placed it near my Aeotec Gen5+ ZStick as the OTA did not work when located in its normal location (1 or 2 hops away). Your situation may be different. If I recall correctly, the sending of a firmware fragment from the controller is acknowledged by the device before another fragment is sent. It kind of looks like your device is getting the download, but maybe it doesn’t like the file (either its corrupted or the wrong type).
I originally had the sensor approximately 2 meters away (about 6.5 feet) from my Aeon Labs ZW090 Gen5 stick. I have now placed the sensor less than 1 inch away from the controller and tried to update again. I did not time the time it takes to download the fragments , but maybe it was a little bit quicker. However, the error remains the same
If the file is incorrect, it seems to be so in both “Update device” section
So, yes I needed to exclude en include them again, but by renaming the same names by reinclusion I did not lost any config or automations.
The firmware update went smooth, 7 devices, every one updated on first shot.
And, watch out, during the firmware update you need to keep them AWAKE by pressing the button every while… When they fall in sleep, they stop receiving
I contacted Silicon Labs and they also suggested Simplicity Studio 5. So I created an account and downloaded the application. Unfortunately there is some kind of bug in the app which prevents me from logging in (there is always only a white area where I suppose that the username and password should be entered) and thus I can’t use the application the way it is intended. I’m sure that SiLabs support will help me overcome this small nuisance…
I was able to start the Windows application, but unfortunately that software sometimes (but not always) showed the same behavior as the one seen using HA. (Other times the update was interrupted when the fw was just partially downloaded)
I contacted support but the answer only adressed the issue of the partial download (“No, you shouldn’t have to keep the sensor alive by pressing the button every now and then, but you can try to press it every five seconds to see if it makes a difference”)
After nomerous tries I ran out of batteries. Since the 2477 is not readily available here in my local town in Sweden I’ve had to order them.
They should arrive shortly and then I hope to continue to try to update the fw.
Please let me know if you’ve had more luck than me.
King regards
Magnus
For anyone having issues with Simplicity Studio software - Run it as administrator. That solved the problem for me.
I tried updating it yesterday using HA and ZwaveJs. Inserted a new battery. It was 100% when I tried the first time. It failed again, although I was finally able to upload the whole firmware.
The battery dropped instantly to 50%. Seems a little strange. Tried two more times after that. Also with pushing the button every few second. That did not help. Only got “invalid payload” errors in the log.
I am looking for an extra Z-wave stick so I can try it with the studio software. Also ordered new batteries. Hopefully I can try it again soon.
It was a long time ago since I took a stab at this, but now it is time again.
Started off by trying to update using HA, but it still fails. All the packages are being downloaded nicely but then it waits for some kind of ack from the device which it never gets.
I then tried Simplicity Studio again.
(Had to remove it and reinstall it since the update process of the application does not seem to work that well)
Disconnected the Aeotec Z-wave stick from my HA machine and attached it to my PC. Followed the same tutorial as previously
Unfortunately I still get suck at the final step (after downloading all the packages). I’ve been waiting for 30 minutes, but still there seems to be some kind of ack missing… I can see that log messages keep on comin in, so the device seems to be responding to commands… However the controller and the device can’t seem to agree with one other that the process is finalized… (Same as in HA)
