AwAcS
(Abhas)
December 15, 2022, 9:13am
1
I am using Home Assistant on Raspberry Pi 3b. Recently, the ESPhome updated to version 2022.12.0 and with that, I am unable to update any of the ESP32. I am able to update esp 8266 chips that are linked with ESPhome, but not the ESP32.
I noticed that with the ESPhome Addon update, the Platformio and Xtensa also updated and that might be causing issues.
I have tried to remove the ESPhome Addon completely with all the files and re-install it, but it did not help.
I have tried to restore to previous backups, but as soon as ESPhome Addon updates, the problem arises again.
Any help in the matter would be of great help.
PS: I am a bit new to linux, so in case I need to update platformIO and xtensa manually, kindly also provide a link to the commands.
Thanks a lot in advance.
It keeps giving the following errors:
INFO Generating C++ source...
INFO Compiling app...
Processing above-wardrobe (board: nodemcu-32s; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/above-wardrobe/.pioenvs/above-wardrobe/src/esphome/components/api/api_connection.cpp.o
sh: 1: xtensa-esp32-elf-g++: not found
*** [/data/above-wardrobe/.pioenvs/above-wardrobe/src/esphome/components/api/api_connection.cpp.o] Error 127
========================== [FAILED] Took 9.71 seconds ==========================```
zoogara
(Daryl)
December 15, 2022, 9:37am
2
I believe it is a known issue that is to do with 32bit / 64bit software - there is a issue open on Github and looks like a PR to fix it:
opened 07:37AM - 14 Dec 22 UTC
### The problem
Compile fails with "sh: 1: xtensa-esp32-elf-g++: not found"
### Which version of ESPHome has the issue?
2022.12.0
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
2022.12.5
### What platform are you using?
ESP32
### Board
esp32dev
### Component causing the issue
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
Platform Manager: Installing platformio/espressif32 @ 5.2.0
INFO Installing platformio/espressif32 @ 5.2.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
INFO Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
Tool Manager: [email protected] +2021r2-patch3 has been installed!
INFO [email protected] +2021r2-patch3 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
INFO Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
Tool Manager: [email protected] has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40201.0
INFO Installing platformio/tool-esptoolpy @ ~1.40201.0
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Update @ 2.0.0
Compiling /data/luftkvalitet1/.pioenvs/luftkvalitet1/src/esphome/components/api/api_connection.cpp.o
*** [/data/luftkvalitet1/.pioenvs/luftkvalitet1/src/esphome/components/api/api_connection.cpp.o] Error 127
========================= [FAILED] Took 371.07 seconds =========================
### Additional information
_No response_
AwAcS
(Abhas)
December 16, 2022, 3:58am
3
Thank you so much for the help. Will wait for someone to post a solution to there.
zoogara
(Daryl)
December 16, 2022, 4:04am
4
I believe 12.1 is out with a fix.
lambu76
(Lambu76)
February 4, 2023, 1:02pm
5
I still have the problem with 2022.12.8 version.
Is it normal?
I don’t have such problem with esp8266
