Unable To Update From 0.100.3
Good Afternoon everyone.
Been trying for weeks to update Hass.io
Looked at everything else on the site and tried everything i have found !
Can anyone help me as i dont no where to go from here:
20-01-02 12:34:42 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.103.5
20-01-02 12:34:42 INFO (SyncWorker_3) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.100.3 to homeassistant/raspberrypi3-homeassistant:0.103.5
20-01-02 12:34:42 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.103.5.
20-01-02 12:44:29 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant application
20-01-02 12:44:36 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant application
20-01-02 12:44:40 INFO (SyncWorker_13) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.103.5
20-01-02 12:54:43 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
20-01-02 12:54:43 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
20-01-02 12:54:43 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.100.3
20-01-02 12:54:43 INFO (SyncWorker_9) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.103.5 to homeassistant/raspberrypi3-homeassistant:0.100.3
20-01-02 12:54:43 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.100.3.
20-01-02 12:54:45 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant application
20-01-02 12:54:47 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant application
20-01-02 12:54:51 INFO (SyncWorker_6) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.100.3
20-01-02 12:55:21 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
20-01-02 12:55:21 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.100.3
20-01-02 12:55:21 INFO (SyncWorker_9) [hassio.docker.interface] Cleanup images: [‘homeassistant/raspberrypi3-homeassistant:0.103.5’]
Cheers everyone for your imput on everything on the site, and happy new year!!!
WDino
do you have api_password: anywhere in your config? Comment it out if you do.
Same issue here: can’t update from 100.2. It does download but installation never finishes and the old version is put back. Why? Log doesn’t tell.
