Unable to update from 2022.4.1
Unsure what’s going on here, I’m running a Suvervised installation on Debian, and getting prompted to update to 2022.4.4.
The backup runs as expected, then nothing. I can run a manual backup, and update without backup with the same effect.
I’m getting 2 errors in the logs at the time, but they don’t seem terribly relevant to me. I’ve tried a full reboot, so I know the system has a clean start, and I have no configuration errors
Source: /usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py:405
First occurred: 10:17:26 AM (1 occurrences)
Last logged: 10:17:26 AM
Unhandled exception
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1183, in _sendfile_fallback
    read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 514, in start
    resp, reset = await task
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 460, in _handle_request
    reset = await self.finish_response(request, resp, start_time)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 613, in finish_response
    await prepare_meth(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_fileresponse.py", line 286, in prepare
    return await self._sendfile(request, fobj, offset, count)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_fileresponse.py", line 99, in _sendfile
    await loop.sendfile(transport, fobj, offset, count)
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1162, in sendfile
    return await self._sendfile_fallback(transport, file,
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1192, in _sendfile_fallback
    await proto.restore()
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 263, in restore
    self._transport.resume_reading()
  File "/usr/local/lib/python3.9/asyncio/sslproto.py", line 343, in resume_reading
    self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'````
And
````Logger: aiohttp.server
First occurred: April 13, 2022, 3:40:32 PM (9 occurrences)
Last logged: 3:57:09 AM
Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 334, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadHttpMessage: 400, message='Pause on PRI/Upgrade'
This ‘Pause on PRI/Upgrade’ I get a lot lately as well. Possibly after 2022.4.x update.
May or may not be related, so this is just FYI: Error handling request · Issue #73084 · home-assistant/core · GitHub
