I’m trying and failing to update ha core from 2024.2.4 to 2024.7.4.
I’m running Home Assistant Supervised
When I try in the UI the status changes to ‘updating’ it spins for a minute or so then finishes with Installed version remaining at 2024.2.4
If I try in the terminal using ‘ha core update’ I see
Processing…
… for a minute or so, then
Processing… Done
… and
Command completed successfully.
but again the version remains at 2024.2.4
In configuration.yaml I set
logger:
default: info
logs:
homeassistant.core: debug
…then tried an update via the UI again but all I see in the logs is:
2024-08-03 17:28:04.404 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=update, service=install, service_data=entity_id=update.home_assistant_core_update, backup=True, version=2024.7.4>
2024-08-03 17:28:04.405 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=update.home_assistant_core_update, old_state=<state update.home_assistant_core_update=on; auto_update=False, installed_version=2024.2.4, in_progress=False, latest_ver…n.png, friendly_name=Home Assistant Core Update, supported_features=11 @ 2024-08-03T17:25:49.386018+01:00>>
2024-08-03 17:28:04.425 INFO (MainThread) [homeassistant.components.recorder] Backup start notification, locking database for writes
2024-08-03 17:28:05.381 INFO (MainThread) [homeassistant.components.recorder] Backup end notification, releasing write lock
2024-08-03 17:28:05.382 INFO (Recorder) [homeassistant.components.recorder.core] Database queue backlog reached 0 entries during backup
I’ve tried ‘Restart Home Assistant’ and ‘Reboot System’ after the updates; this doesn’t help.
I’ve tried restarting in safe mode, then updating; this doesn’t help.
I’ve checked that there is plenty of free disk space on the server.
Any suggestions please?
