Hi there, i tried a hundred times but i doesnt work.
20-02-29 19:20:46 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-02-29 19:25:59 ERROR (SyncWorker_13) [hassio.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:0.106.2 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-homeassistant:0.106.2: No such image: homeassistant/raspberrypi4-homeassistant:0.106.2").
20-02-29 19:25:59 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
20-02-29 19:25:59 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock.<locals>.wrap_api() done, defined at /usr/src/hassio/hassio/utils/__init__.py:20> exception=HomeAssistantUpdateError()>
