Unable to update Home Assistant Operating System from 14.0 to 14.1
I currently run HA on an Odroid n2+
So everytime I click the “update” button for updating the HA OS from 14.0 to 14.1 I get an error saying I need to check the supervisor logs.
There I find the following:
2025-01-21 10:37:58.914 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://os-artifacts.home-assistant.io/14.1/haos_odroid-n2-14.1.raucb
2025-01-21 10:38:02.077 INFO (MainThread) [supervisor.os.manager] Completed download of OTA update file /data/tmp/hassos-14.1.raucb
2025-01-21 10:38:04.923 ERROR (MainThread) [supervisor.os.manager] Home Assistant Operating System update failed with: Installation error: Failed updating slot kernel.0: Syncing content to disk failed: Input/output error
So I thought that mabye the flashdrive was failing (yeah I know) so I moved the datadisk to an SSD.
But the error remains the same.
I did a lot of trail and error installations so I’m not really sure but I think the OS is installed on the eMMC, or it might be the USB, any way to find out?
and what can I do to repair this issue?
MANY MANY thanks in advance!
