I have been using an add to connect with my car (PSA car controller). It had worked well up to a month ago, but refused to update… So I have removed all images and uninstalled it.
However, I’m now not able to re-install (other adds will install fine) and I get the following:
Logger: homeassistant.components.hassio Source: components/hassio/websocket_api.py:138 Integration: Home Assistant Supervisor (documentation, issues) First occurred: 11:15:04 (3 occurrences) Last logged: 11:27:15
Failed to to call /addons/b9f12d83_psacc/install - Can’t install flobz/psa_car_controller:v3.2.0: 404 Client Error for http+docker://localhost/v1.43/images/flobz/psa_car_controller:v3.2.0/json: Not Found (“No such image: flobz/psa_car_controller:v3.2.0”)
Any help gratefully received…
Running HA on a Raspberry Pi:
Core 2023.12.0
Supervisor 2023.11.6
Operating System 11.2
Frontend 20231206.0
I had the same problem and this is how I solved it:
First go to the plugin page in the settings and then to the affected plugin. Execute the update from the plugin. Then it works.
I had the same problem today and came across this page while looking for a solution. As others probably have the same problem, I wanted to add this further solution here. Maybe it will help other people too.
The procedure works well, however I have to do the procedure again at each update. And also my add-on stops from time to time (I suspect that it fails to start after HA reboot).
Would be cool if anyone has a complete solution (other than reinstall everything).
