Unable to update Supervisor or HomeAssistant
When I run hassio supervisor update from SSH I get :
parse error: Invalid numeric literal at line 1, column 23
When I check supervisor logs :
18-01-03 21:52:09 INFO (MainThread) [hassio.dock.supervisor] Update supervisor docker to homeassistant/armhf-hassio-supervisor:0.78
18-01-03 21:52:09 INFO (SyncWorker_12) [hassio.dock.interface] Pull image homeassistant/armhf-hassio-supervisor tag 0.78.
18-01-03 21:52:10 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 601, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 387, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 383, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.6/http/client.py”, line 1331, in getresponse
response.begin()
File “/usr/lib/python3.6/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.6/http/client.py”, line 266, in _read_status
raise RemoteDisconnected(“Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 440, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3.6/site-packages/urllib3/util/retry.py”, line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3.6/site-packages/urllib3/packages/six.py”, line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
response.begin()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’,))
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 410, in start
resp = yield from self._request_handler(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web.py”, line 325, in _handle
resp = yield from handler(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_middlewares.py”, line 93, in impl
return (yield from handler(request))
File “/usr/lib/python3.6/site-packages/hassio/api/util.py”, line 33, in wrap_api
answer = await method(api, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/hassio/api/supervisor.py”, line 102, in update
self.supervisor.update(version), loop=self.loop)
File “/usr/lib/python3.6/site-packages/hassio/dock/util.py”, line 18, in wrap_api
return await method(api, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/hassio/dock/supervisor.py”, line 53, in update
if await self.loop.run_in_executor(None, self._install, tag):
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/hassio/dock/interface.py”, line 69, in _install
image = self.docker.images.pull(”{}:{}”.format(self.image, tag))
File “/usr/lib/python3.6/site-packages/docker/models/images.py”, line 280, in pull
self.client.api.pull(name, tag=tag, **kwargs)
File “/usr/lib/python3.6/site-packages/docker/api/image.py”, line 390, in pull
stream=stream, timeout=None
File “/usr/lib/python3.6/site-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/docker/api/client.py”, line 187, in _post
return self.post(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 555, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 508, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 618, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 490, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’,))
When I run
hassio homeassistant update
I get the same result, but nothing is added to the homeassistant logs.
I’m running Supervisor version 0.76 and HomeAssistant 0.59.2 on a Raspberry pi (type Resinos, host control version 1.0)
I have beel looking around on the forums, tried some stuff, rebooting, changed how the base-url was set (with or without https:// or portnumber as referred in another topic) no success…
Hoping someone has an idea on how to get this fixed…
I get the same error sometimes, when trying to start home assistant from command line “hassio homeassistant start”.
To solve the problem, I have to reboot the PI 3 manually (turn it off and on again)
Home assistant version is 0.60
