I’m not able to update to the latest home-assistant version using either the user interface nor the hassio updater. The call results in a bad request, but I cannot seem to find out why.
~ $ hassio homeassistant update --version=0.103.5 --log-level=debug --no-progress
DEBU[0000] Adding homedir to searchpath homedir=/root
INFO[0000] No configfile found
DEBU[0000] Debug flags apiToken= REMOVED_API_TOKEN cfgFile= endpoint=hassio logLevel=debug noProgress=true rawJSON=false
DEBU[0000] homeassistant update args="[]"
DEBU[0000] [GenerateURI] base=hassio command=update section=homeassistant
DEBU[0000] [GenerateURI] Result uri="http://hassio/homeassistant/update" url="http://hassio/homeassistant/update" url(string)="http://hassio/homeassistant/update"
DEBU[0000] Request body body="map[version:0.103.5]"
DEBU[0024] Response body="{\"result\": \"error\", \"message\": \"Unknown Error, see logs\"}" fields.time=24.372525672s headers="map[Content-Length:[57] Content-Type:[application/json; charset=utf-8] Date:[Tue, 31 Dec 2019 09:55:14 GMT] Server:[Python/3.7 aiohttp/3.6.1]]" recieved-at="2019-12-31 10:55:14.708156008 +0100 CET m=+24.383147224" request="&{POST http://hassio/homeassistant/update HTTP/1.1 1 1 map[Accept:[application/json] Authorization:[Bearer REMOVED_API_TOKEN] Content-Type:[application/json] User-Agent:[go-resty/2.1.0 (https://github.com/go-resty/resty)] X-Hassio-Key:[REMOVED_API_TOKEN]] {} 0x2d1c74 21 [] false hassio map[] map[] <nil> map[] <nil> <nil> <nil> <nil>}" status="400 Bad Request" statuscode=400
I then saw this url; http://hassio
, but that seems to resolve properly:
config $ ping hassio
PING hassio (172.30.32.2): 56 data bytes
64 bytes from 172.30.32.2: seq=0 ttl=64 time=0.373 ms
64 bytes from 172.30.32.2: seq=1 ttl=64 time=0.308 ms
The supervisor logs says:
19-12-31 10:03:53 INFO (MainThread) [hassio.api.security] /homeassistant/update access from core_ssh
19-12-31 10:03:53 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.103.5
19-12-31 10:03:53 INFO (SyncWorker_15) [hassio.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.103.4 to homeassistant/raspberrypi4-homeassistant:0.103.5
19-12-31 10:03:53 INFO (SyncWorker_15) [hassio.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.103.5.
19-12-31 10:04:02 ERROR (SyncWorker_15) [hassio.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:0.103.5 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-homeassistant:0.103.5: No such image: homeassistant/raspberrypi4-homeassistant:0.103.5").
19-12-31 10:04:02 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
I’ve found some topics stating that diskspace could be an issue, but it seems like there’s plenty.
config $ df -h
Filesystem Size Used Available Use% Mounted on
overlay 28.0G 3.1G 23.4G 12% /
tmpfs 64.0M 0 64.0M 0% /dev
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/root 91.0M 91.0M 0 100% /dev/init
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /data
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /config
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /ssl
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /addons
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /backup
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /share
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /etc/resolv.conf
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /etc/hostname
/dev/mmcblk0p8 28.0G 3.1G 23.4G 12% /etc/hosts
shm 64.0M 0 64.0M 0% /dev/shm
tmpfs 1.9G 0 1.9G 0% /proc/asound
tmpfs 64.0M 0 64.0M 0% /proc/keys
tmpfs 64.0M 0 64.0M 0% /proc/latency_stats
tmpfs 64.0M 0 64.0M 0% /proc/timer_list
tmpfs 64.0M 0 64.0M 0% /proc/sched_debug
tmpfs 1.9G 0 1.9G 0% /sys/firmware
Can anybody point me in the right direction on how to update home assistant?
