Hey gang,
I recently received a notification that version 0.70.1 was out, so I logged in to update like normal but am unable to do so.
core-ssh:~# hassio ha update
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2c7050, 0x1070b620)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x33c
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107b6200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x3c8
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2f6f83, 0xd, 0x7ebf5e64, 0x6, 0x0, 0x0, 0x76500, 0x0, 0x0, 0x0, ...)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x308
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x10778580)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/homeassistant.go:48 +0x540
github.com/urfave/cli.HandleAction(0x2af768, 0x324b14, 0x10778580, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0xf0
github.com/urfave/cli.Command.Run(0x2f6f83, 0xd, 0x0, 0x0, 0x40bd10, 0x1, 0x1, 0x301e4d, 0x2f, 0x0, ...)
/home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x6b8
github.com/urfave/cli.(*App).Run(0x107648c0, 0x1070a160, 0x3, 0x4, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x8b0
main.main()
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x108
core-ssh:~# hassio ha info
"result": "ok",
"data": {
"version": "0.69.1",
"last_version": "0.70.1",
"machine": "raspberrypi3",
"image": "homeassistant/raspberrypi3-homeassistant",
"custom": false,
"boot": true,
"port": 8321,
"ssl": false,
"watchdog": true,
"wait_boot": 600
core-ssh:~#
I just rebooted to see if that fixes the issue but am still unable to complete the upgrade. any advice? i’m not really sure where to even begin with this one.
