Nothing happens by the UI and when i try from the ssh prompt i get this error:
core-ssh:~# hassio homeassistant status
No valid action detectedcore-ssh:~# hassio homeassistant update
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2c5f60, 0x107b44a0)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x33c
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107c0200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x3c8
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2f5e63, 0xd, 0x7ee11e61, 0x6, 0x0, 0x0, 0x76000, 0x0, 0x0, 0x0, …)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x308
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x10780420)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/homeassistant.go:48 +0x540
github.com/urfave/cli.HandleAction(0x2ae6d8, 0x323754, 0x10780420, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0xf0
github.com/urfave/cli.Command.Run(0x2f5e63, 0xd, 0x0, 0x0, 0x409d10, 0x1, 0x1, 0x300cfa, 0x2f, 0x0, …)
/home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x6b8
github.com/urfave/cli.(*App).Run(0x1076c8c0, 0x1070a160, 0x3, 0x4, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x8b0
main.main()
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x108
Any suggestions what can be wrong? running Hassio 0.66.1
