Couple days ago i was notified there is a new update for home assistant available. I logged on to the /hassio
button and attempted to launch the update.
However, i was greeted with an error: Unable to load the panel source: /api/hassio/app/entrypoint.js.
Unsure of how to troubleshoot this, I attempted to reboot the device. I connected via SSH to the device and ran hassio host reboot
which gave me an error as well: The HTTP request failed with the error: Post http://hassio/host/reboot: dial tcp: lookup hassio on [::1]:53: dial udp [::1]:53: connect: cannot assign requested address
There are no worthwhile errors that I found in the main log. At this point I am unsure of where to go or what to do. Can anyone assist?
Thanks in advance.
So i pulled the power and rebooted the device. Seemed to come back up ok, but still can’t update or reboot. Now when I SSH onto the pi and run hassio host reboot
I get the following error:
core-ssh:~# hassio host reboot
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2c7050, 0x107b43c0)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x33c
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107be200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x3c8
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2f45fc, 0x4, 0x7eef1e64, 0x6, 0x0, 0x0, 0x76500, 0x0, 0x0, 0x0, ...)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x308
github.com/home-assistant/hassio-cli/command.CmdHost(0x10780420)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/host.go:42 +0x4f0
github.com/urfave/cli.HandleAction(0x2af768, 0x324b18, 0x10780420, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0xf0
github.com/urfave/cli.Command.Run(0x2f45fc, 0x4, 0x0, 0x0, 0x40bd20, 0x1, 0x1, 0x2fabdf, 0x18, 0x0, ...)
/home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x6b8
github.com/urfave/cli.(*App).Run(0x1076c8c0, 0x1070a160, 0x3, 0x4, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x8b0
main.main()
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x108
I attempted to run the update from the web interface but it crashed home assistant. I power cycled the raspi again, and it reverted back to 0.73
Now I am attempting to run it from SSH and it’s simply not advancing. Home assistant keeps running but nothing is updating.
Having the same problem. Am on 0.74.0 and got a message that 0.74.1 was available. But cannot access hass.io in left hand panel, getting same error message:
alikr
(Alik)
July 25, 2018, 6:06am
5
Same problem here
Updated to 0.74.1
core-ssh:~# hassio ha restart
ERROR
panic(0x2c7050, 0x1070b660)
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput (0x107c0200, 0x24, 0x200, 0x0)
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand (0x2f6f83, 0xd, 0x7ec9de64, 0x7, 0x0, 0x0, 0x76500, 0x0, 0x0, 0x0, …)
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x107804d0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/homeassistant.go:48 +0x540
github.com/urfave/cli.HandleAction (0x2af768, 0x324b14, 0x107804d0, 0x0, 0x0)
github.com/urfave/cli.Command.Run (0x2f6f83, 0xd, 0x0, 0x0, 0x40bd10, 0x1, 0x1, 0x301e4d, 0x2f, 0x0, …)
github.com/urfave/cli.(*App ).Run(0x1076c8c0, 0x1070a160, 0x3, 0x4, 0x0, 0x0)
main.main()
Any ideas what to do ?
0rn0lf
(0rn0lf)
July 25, 2018, 6:54am
6
Same here, i think its the new supervisor. But how to downgrade?
Krycek
(Mika)
July 25, 2018, 6:55am
7
0.74.0 here. And I am also seeing ”Unable to load the panel source: /api/hassio/app/entrypoint.js.” when opening Hass.io menu on left panel.
Running on raspi3.
0.74.0 also have the same situation ”Unable to load the panel source: /api/hassio/app/entrypoint.js.” when opening Hass.io menu on left panel. Running on raspi3. And it happen after trying to install supervisor 120
I had this problem because I did not have enough free space on my drive. I ended up removing add ons to get enough space (around 1gig) then I could update ok.
I run off a USB stick so have to expand the docker file - followed a guide and did not give myself enough space and started running into space issues. New install on the weekend and I used all the drive space so have neearly 9GB space now.
df
will tell you how much space you have
Used Available Use% Mounted on
none 13817880 4270336 8816064 33% /
tmpfs 497776 0 497776 0% /dev
tmpfs 497776 0 497776 0% /sys/fs/cgroup
/dev/sda2 301209 231250 49889 82% /dev/init
/dev/sda6 13817880 4270336 8816064 33% /config
alikr
(Alik)
July 25, 2018, 9:02am
10
My problem with panic: interface conversion: interface is nil, not string fixed by downgrading to an older version thru ssh:
core-ssh:~# hassio ha update -o “version=0.72.1”
Good luck
p3xx69
(Chrisss)
July 25, 2018, 4:12pm
11
Hi all
Same issue , ican’t start HA , after update on the version 0.74.1
➜ ~ hassio homeassistant restart
ERROR
panic(0x2c7050, 0x107ac320)
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107b6200, 0x24, 0x200, 0x0)
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2f6f83, 0xd, 0x7efd4dba, 0x7, 0x0, 0x0, 0x76500, 0x0, 0x0, 0x0, ...)
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x10778420)
github.com/urfave/cli.HandleAction(0x2af768, 0x324b14, 0x10778420, 0x0, 0x0)
github.com/urfave/cli.Command.Run(0x2f6f83, 0xd, 0x0, 0x0, 0x40bd10, 0x1, 0x1, 0x301e4d, 0x2f, 0x0, ...)
github.com/urfave/cli.(*App).Run(0x1070ca80, 0x1070a180, 0x3, 0x4, 0x0, 0x0)
main.main()
What is the solution ???
durtoff
(Durtoff)
July 25, 2018, 4:38pm
13
rebooting the rpi should fix that
cogneato
(Cogneato)
July 25, 2018, 5:31pm
14
The solution seems to be to wait. There’s a bug which is increasing the time to update (15 mins).
I lost the hassio panel first as described further up in this thread, then the connection, then 10 to 15 minutes later it was up again.
Same issue I downgraded to 0.72.1
You need to reboot first and ensure HA has started correctly by running
hassio ha logs
then
hassio ha update -o ‘version=0.72.1’
be patient takes about 10 mins for the cursor to reappear
takje
(X)
July 25, 2018, 6:29pm
16
Is there a reported bug somewhere? Downgrading only seams like half a solution.
Its a bug see
I suspect you could downgrade to 0.74 and all would be Ok. I thought is would be safer to downgrade to a version before the new Auth code was introduced and wait for the fix.
takje
(X)
July 25, 2018, 8:24pm
18
I find it often confusing to keep track of github. There are too many github repositories: hassio, Hass os, home assistant, addons,…
Thanks for sharing.
p3xx69
(Chrisss)
July 25, 2018, 9:36pm
19
Hi
How to downgrade the version 0.74.1 to 0.74.0 ???
Have you a link to do this operation ?
It’s the first time for me
Thansk by advance
p3xx69
(Chrisss)
July 25, 2018, 9:59pm
20
ok it’s fine with this command
hassio ha update -o version=0.74.0
I saw that hte version 0.74.2 is available , are you sure we can install it ?
Let me know please
"0.74.0 ”Unable to load the panel source: /api/hassio/app/entrypoint.js.”
Solved only by hard reset of rpi: removing power, waiting 10sec, replugging power.
